Transmission Removal Question - Page 2 - Defender Source
Old June 24th, 2014, 11:18 AM
A transfer case swap is easy in a Defender. A rope through the center seatbox access panel and you can pull it off by hand. You do not need a jack or to take the seatbox off.
Old June 24th, 2014, 11:23 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
transfer case only might not be that hard, but last time I pulled out the whole package we had to be 3 under it to lower it by hand, not funny.
What do you guys use for plate and cover, Valeo or Borg & Becker ?
Cheers
- Charles Eames
transmission
New Transmission Question Joe P Defender Technical Discussions 14 August 10th, 2011 02:20 PM
Need help with Transmission question. michael15 Defender Technical Discussions 7 February 8th, 2006 10:44 AM
'94 clutch and transmission question CDN38 Defender Technical Discussions 4 January 31st, 2006 01:32 PM
ZF4HP22 transmission question..... kiphartzell Defender Technical Discussions 9 December 28th, 2005 09:11 AM
Exhaust Pipe Removal Question Rob Defender Technical Discussions 0 September 17th, 2004 02:27 PM
