Transmission mount help! - Defender Source
Old July 25th, 2010, 03:43 PM
timetravel
Jesse Blythe
1983 110 HCPU
I'm in need of the transmission bracket and mount on the left side for my 1983 110.
LT77 mainshaft output splines and LT230 input gear roasted while I was visiting my parents in NC.. over Thanksgiving.
So in April I had time to get back down to the truck and pulled the transfer case and transmission. I ordered ashcroft's short bellhousing r380 as well as new input gear and rebuild kit for LT230. Took the LT230 back with me to rebuild it, as well as the turret to make sure it mated up nicely with the r380. Drove back to Chicago in a backup vehicle. Was lucky enough to unload the transmission and parts that night, because when I woke up the Honda had been stolen.
Just drove back down from Chicago to NC again, popped the transmission and transfer case on only to realize that the transmission mount and bracket are no longer on the old transmission. It was in the Honda, somehow didn't get unloaded, and undoubtedly was scrapped for $.25 by some car thief's neighborhood alley scrapper.
SO, phew, I'm in a pickle. I absolutely have to go back to Chicago by thursday and the truck has got to move because I've been on borrowed space for quite some time. If anyone has a source for the bracket and mount, a spare one, or even critical dimensions so that I could make one I'd be so entirely grateful. I've got a feeling I'm fairly well hosed, because who would need to replace the frame mounted bracket (aside from me)?
Right now I'm in the Pinehurst/Southern Pines, NC area. Any help, information, ideas, whatever would be super helpful. I'll be checking the thread, but I'll throw my tele# out there (Eight47) 217-745Eight call at anytime.
Cheers,
Jesse
Old July 25th, 2010, 04:43 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Have you tried Rovers North?
Old July 25th, 2010, 05:56 PM
There are a ton of D90 guys in NC, too bad you could not have found the forum earlier.
PM Dale (RoverTrader) he or DrAaron may have the parts you need and they are in NC.
Old July 25th, 2010, 06:17 PM
timetravel
Jesse Blythe
1983 110 HCPU
Nope, just realized that I'm missing the mount today. I have a small list of places to call tomorrow morning.. Rovers north, rovers down south, British Atlantic, southwest rovers, maybe east coast rovers. Frankly I'm a little concerned that no one is going to have the frame mounted bracket. The rubber mount should be cake to find.
Thanks for the idea, any other places that might be worth a call?
------ Follow up post added July 25th, 2010 04:23 PM ------
Thanks Scott, will do
Old July 26th, 2010, 09:11 PM
timetravel
Jesse Blythe
1983 110 HCPU
Thanks for the help folks.. This was a very pleasant glimpse at the land rover community here in the states. It appears that I may have the correct mount on the way with many thanks to Rob at Southwest Rovers. Second time in a week he's come through for me.
Old July 26th, 2010, 09:24 PM
glad you got the part. in a pinch you could probably use a couple 2 x 4's and a ratchet strap or two.
Old July 26th, 2010, 09:56 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
Rob,
Is the Best help a man can find. He has done several things to my 90.
mount, transmission
transmission mount Paul Davis Defender Technical Discussions 4 June 18th, 2010 07:02 PM
ZF4HP22 transmission question..... kiphartzell Defender Technical Discussions 9 December 28th, 2005 09:11 AM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
ARB Bumper 97 Transmission Cooler Caution dnewman9 Defender Technical Discussions 4 September 8th, 2004 12:51 AM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
