Transmission Leak - Defender Source
Old March 22nd, 2007, 09:27 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Transmission Leak
Hello Guys,
A couple of weeks ago I was topping up all the fluids in my Rover. When I got
to the transfer case I took the fill plug out and it was over full and the gear oil
that came out had a reddish tinge. My first thought was "great, rust in the transfer
case". Then, I went to top up the transmission with ATF and it was low. Ding...then
the light went on. I went and checked the gear oil in the transfer case again and I think
it's contaminated with ATF. Since the transmission has been low again and the t-case
is even more over full and more red. My question is what is the connection between the
two...I mean is it an O-ring, a shaft seal or what? I hope I can remove the t-case
without removing the tranny and I figure someone else has done that, maybe because of
this same problem. Any help is appreciated.
Bryan
95 D90 HS2.8TGV
Old March 23rd, 2007, 06:32 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Sounds like a blown output shaft seal
Part Number ICV100000
Description REAR OIL SEAL LT77
Retail Price $7.14 exc. VAT (Rimmer Bros.)
Can probably find it state-side without a problem, just easy to find part numbers on that site.
Some people are like a slinky... not really good for anything, but you still can't help but smile
when you shove them down
the stairs.
Old March 23rd, 2007, 10:21 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
The transmission & t-box are separate units that use separate oils. there are 2 seals that separate the gearboxes with a small hollow space between them. The space between them contains a drain slot. I have never seen LR boxes cross contaminate fluids. I have seen people seal the transfer case to the transmission. If the drain slot was completely plugged it may be possible to cross contaminate the fluids. I would probe the drain slot with a piece of stiff wire...if you have transmission oil come out, that will prove your theory. What transmission are you using?
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old March 23rd, 2007, 01:39 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Transmission is a R380
I'll check for the plugged drain tonight. Haven't been in mud in a long time..
so if it is clogged it would have to caused by something else.
Thanks.
Old March 23rd, 2007, 04:30 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
The part number above is for the transmission side. The other should face the opposite direction (sealing the transfer case) so I did not include that number. I would be happy to find it for you if needed.
the stairs.
Old March 23rd, 2007, 06:27 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
Thanks Scott but...
I ordered the transfer case and transmission seals from George at RDS.
I do appreciate the offer though.
Thanks to you to Rob.
Old March 24th, 2007, 02:15 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Sweet, hope everything goes well on the R&R.
the stairs.
transmission
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
Engine Oil Leak Question ronward Defender Technical Discussions 0 March 22nd, 2005 09:38 AM
ARB Bumper 97 Transmission Cooler Caution dnewman9 Defender Technical Discussions 4 September 8th, 2004 12:51 AM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
