Transmission fluid change resulted in Engine Warning Light? - Defender Source
Old June 23rd, 2013, 12:18 PM
silverlight's Avatar
silverlight
Geoff
1993 Defender 110 NAS
Hi - any ideas on where to troubleshoot? Given I have a sticky and rough transmission in terms of shifting I did another flush and change of transmission fluid. Defender 110 NAS 1993 with LT77 tranny. Used Red Line MTL fluid (which was recommended to me) plus a dose (1 0.7 litre bottle) of Lucas Transmission Fix. The combination has resulted in a butter smooth transmission, however the red engine light is now coming on. For reference it's never come on in the past 3 years, so seems like a pretty clear cause and effect. It's worth noting that I filled when engine was cold up to the fill hole level so that a slight amount was dripping out. I checked level cold and warm (at warm there was fluid leaking out). Also worth mentioning that while the capacity level chart suggests 2.67 litres, I only was able to fill with a little over 2 litres including the Lucas TF. Thanks in advance for thoughts!
Geoff
Old June 23rd, 2013, 12:30 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Well, let's start with what code is showing up on the diagnostic display?
There is really no computer connection to the tranny as far as I know, but while you were down there you may have hit an O2 sensor or wiring or something else...
Old June 23rd, 2013, 12:31 PM
Geoff
How many miles on the 110? Could be that you just randomly crossed the threshold where the Service Engine light typically comes on (assuming this is the one you're referring to). Doing the trans fluid won't affect this light I believe.
------ Follow up post added June 23rd, 2013 12:33 PM ------
Doesn't an O2 throw the yellow CEL, not the red Service Engine?
Old June 23rd, 2013, 01:16 PM
silverlight
Geoff
Here are responses to the above:
(1) miles are about 44,000 original miles
(2) just checked the diagnostic box and it read #88. So I looked it up and read about next steps on this code, so I cycled it and then got #02 and the engine light went off, followed by blank on the diagnostic when starting the engine. So it appears whatever it was cleared itself and didn't come back.
So not sure what happened, but the transmission is working far better which I'm happy about just want to make sure I didn't do anything else along the way!
Thanks for the help and let me know if you think this closes the loop or if there's something else I should check.
Old June 24th, 2013, 10:18 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Code 88= purge valve leak
Old June 24th, 2013, 11:26 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
It might have stopped leaking oil temporarily, which causes the computer to throw the "out of oil" code. Classic Rover engineering.
Old June 24th, 2013, 11:36 AM
silverlight
Geoff
I have noticed a very slow oil leak which drips from just below the transmission.
Will keep an eye on it to see if it continues but perhaps that was the source.
engine, transmission
emmisions control reminder - service engine light JKC Defender Technical Discussions 5 September 28th, 2011 09:42 AM
first oil change after breaking in new engine Davis Defender Technical Discussions 15 May 2nd, 2010 12:21 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
