transmission drain plug fell out!? - Defender Source
Old June 24th, 2015, 05:42 PM
4x4Canada
a
1994 Defender 110 300tdi
so about a 2 months i was doing a pre-trail inspection on my brothers 110 and i noticed the drain plug on the tranny was missing. it must have been missing for at least 4k miles because thats when it started to pick up a bit of a grind going into 2nd and 4th. so anyways after a month of waiting i dont think the drain pug that he ordered from the uk is going to show up. so im not to knowledgeable in the exact workings of a transmission, nor is my brother, it hasn't been started since i saw it was missing so if i were to start it with the clutch pressed, the transmission wouldnt spin at all, right? and also if anyone would happen to know if there are another drain plugs off of any other trannys that would be compatible with the r380, that'd be great! Thanks
Old June 24th, 2015, 06:13 PM
No way it went 4,000 miles without fluid. Are you sure it isn't the bell housing wading plug that is missing? Post up a photo.
Old June 24th, 2015, 06:24 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, the first thing that came to mind as well.
Semper Fi!
Old June 24th, 2015, 06:26 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
It might have gone 4 miles without a drain plug. I doubt 4k.
Although Prins did finish a Dakar race a few years back with an R380 that had lost fluid. First, 2nd, and 3rd had failed. They crossed the finish line with just 4th and 5th.
Black Rhino Lives Matter
Old June 25th, 2015, 04:21 PM
4x4Canada
a
it was definitely the drain plug, down and to the left of the torx fill plug. it finally came in the mail this morning, after a flush and a fill it wont take second above 15km now
Old June 25th, 2015, 04:51 PM
That sucks. Probably needs a rebuild.
Old June 25th, 2015, 10:13 PM
4x4Canada
a
it was rebuilt 260k miles ago so it was probably due soon anyways. off topic but i found its old ad from a few owners back couple days ago if anyone wants to see
http://porthawkesbury.allcarsincanad...on_198467.html.
drain, drain plug, transmission
Transfer Case Drain Plug Problem kzack Defender Technical Discussions 10 October 21st, 2010 08:14 AM
Wading plug and drain hole? T.U. Defender Technical Discussions 4 April 6th, 2010 03:48 PM
Drain Plug Diffs/Xfer Case Grover Defender Technical Discussions 7 November 11th, 2009 11:21 PM
where is drain plug for the swivel housing UpnOver Defender Technical Discussions 10 July 23rd, 2007 03:23 PM
Oil pan drain plug thread Pat Defender Technical Discussions 0 June 23rd, 2006 09:02 AM
