transmission drain and fill - Page 2 - Defender Source
Old November 15th, 2011, 05:08 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
changing from redline?
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old November 15th, 2011, 05:23 PM
Was just going to try something different amsoil is redily available
Old November 15th, 2011, 05:47 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
As long as it meets the specs I don't see why it wouldn't.
FWIW I get my Redline at a local speed shop.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 15th, 2011, 09:51 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
You can pick up redline at global offroad and diesel if you still wanted redline. At least that's where I last picked it up.
1995 Defender ST
1996 Discovery SE7
Old November 16th, 2011, 02:31 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Originally Posted by rover4x4 View Post
Is anyone using the AMSOIL MTF?
I am, I have no idea what was in there before I changed it, but its definitely shifting better now that I did.
http://www.amsoil.com/storefront/mtf.aspx
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
drain, transmission
changing transmission oil ini88 Defender Technical Discussions 15 March 26th, 2009 08:46 PM
300Tdi Oil Change Process ronward Defender Technical Discussions 7 August 27th, 2006 03:59 PM
Aux fuel kolvedic Defender Technical Discussions 19 February 2nd, 2006 09:57 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
