Transmission cooler - Defender Source
Old September 23rd, 2016, 03:11 PM
MMC415
Marc C
1997 D90 LE
Transmission cooler
I have a 1997 NAS D90 with Automatic Transmission. I am having a damaged oil cooler line replaced. In removing the old lines from the cooler assembly the fittings were stripped. At first I was told that the cooler would need to be replaced (Part # FTC5360). But both of the big guys are out of stock and the item is back-ordered with no ETA!?
My question is does anyone sell or fabricate the fittings that attach to the cooler itself. I'd rather not have to replace the whole thing even if it was available but it's not.
Thanks in advance for any help or advice.
Old September 23rd, 2016, 03:46 PM
ezzzzzzz
Mark Garrenton
If you want the cooler LRSeries has it for around $165 plus shipping if my calculations are good. Rimmerbros has it for $210 plus shipping.
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old September 23rd, 2016, 10:28 PM
MMC415
Marc C
1997 D90 LE
Thanks...!
Old September 23rd, 2016, 11:07 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I might have the fittings, can you post a pic?
Rent my
Old September 23rd, 2016, 11:58 PM
MMC415
Marc C
1997 D90 LE
I might have the fittings, can you post a pic?.
The actual unit is in the shop, but here's the link on RN
OIL COOLER ASSY TRANSMISSION DEFENDER, FTC5360 - Rovers North - Classic Land Rover Parts
If you expand the picture you can see the two round fittings. Thanks for looking!
Old September 25th, 2016, 12:28 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
OK, I'll check for them today.
Rent my
Old September 25th, 2016, 02:42 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Well Marc, one fitting is useable but the other was stripped. Probably like yours, due to corrosion. I did check the fitting on the right and it threads into a cooler line ok but the left one is no good. Sorry!
As you can see from the picture, I need an entire cooler but I have an alternative I can use for now! Lol
Rent my
Old September 25th, 2016, 02:46 PM
You can get an after market one for $40. You will have to modify the lines to make it work. I had to do that on mine, when I added the Safari Gard brush bar.
Old September 25th, 2016, 04:55 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Bad thing about the stock cooler is it's down below the pull of air from the engine fan. So when you need it most, slow & off road, it's effectiveness is almost nill. Going down the highway, it's fine, wheelin', it's almost worthless. An aftermarket in front of the AC condenser is a better location.
Old September 25th, 2016, 11:00 PM
MMC415
Marc C
1997 D90 LE
As you can see from the picture, I need an entire cooler but I have an alternative I can use for now! Lo.
That's them! Damn...I'm getting pretty close!
Thanks so much for checking Jeff. At least the cooler in the pic actually needs to be replaced!
Old October 10th, 2016, 05:26 PM
MMC415
Marc C
1997 D90 LE
LR Part FTC5360
So the Transmission Cooler (Part No FTC5360) is officially out of stock and back-ordered until at least December. I tried RoversNorth Atlantic British as well as LR Series and Rimmer brothers.
Does anyone know where I could get a new one or a high quality used one with the fittings intact?
Thanks in advance for the help.
Old October 10th, 2016, 05:41 PM
I have a couple new ones in stock but would need it replaced.
Old October 10th, 2016, 06:22 PM
MMC415
Marc C
1997 D90 LE
Wow...that's great! Sent you a PM.
Marc
transmission
Pelican Elite Cooler 95qt. Trades for smaller cooler or... speedpin The Flea Market 8 June 19th, 2015 02:59 PM
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
WTB 97' D90 auto transmission cooler pendy Wanted 15 September 28th, 2005 08:12 PM
transmission cooler lines J4hand Defender Technical Discussions 0 February 3rd, 2004 04:27 PM
