Transmission clicking? - Defender Source
Old June 14th, 2005, 06:03 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
My transmission makes a rather defined click sound while letting off the clutch. It is not from the pedal (I have noticed that the spring mechanism on the actual pedal makes a clicking sound some times), but very distinctly comming from the engine. It is most evident while switching from 2nd to 3rd gear. Any clue?
Old June 14th, 2005, 06:42 AM
The throw-out (clutch release) bearing can make a variety of sounds as it wears out or if it gets loose. If probably isnt a serious condition, but it naturally should be rectified. Its a cheap part, its just buried.
Theres my long-distance diagnosis
transmission
Clicking noise from behind IP - 97 D90 Saito Defender Technical Discussions 3 March 28th, 2006 11:17 AM
Need help with Transmission question. michael15 Defender Technical Discussions 7 February 8th, 2006 10:44 AM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
ARB Bumper 97 Transmission Cooler Caution dnewman9 Defender Technical Discussions 4 September 8th, 2004 12:51 AM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
