Transmission Brake Removal - Defender Source
Old January 20th, 2018, 04:10 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
I'm in the process of rebuilding the transmission brake. Right now I'm about to take the transmission brake back plate off but before I do so I want to know if I have to remove the drive flange as well so it has enough room to slide off. I'd like avoid draining the transfer box oil.
I'd like to take the backplate completely off, clean it, and paint it. Thanks!
It's and lt77 and lt30 on an '86 110.
Old January 20th, 2018, 05:06 PM
The drive flange can stay on. Always pull the whole thing to rebuild on the bench.
Old January 20th, 2018, 05:14 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Great, thanks!
brake, transmission
Brake Switch Removal - 1997 D-90 JKC Defender Technical Discussions 12 January 12th, 2017 03:24 PM
Transmission Removal Question edh Defender Technical Discussions 21 June 24th, 2014 11:23 AM
Blew u-joint in rear, help on 4 bolts removal on brake drum UpnOver Defender Technical Discussions 3 February 2nd, 2012 07:53 PM
