Transmission brake drum - Defender Source
Old May 19th, 2012, 07:33 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
The previous owner backed off the parking brake because it got stuck while sitting for an extended period. So I'm finally getting round to checking it out (almost a year!)
I took the rear prop shaft off, removed the two counter sunk screws but I can't get the drum off. Am I missing something? I've beat on it with a mallet but no luck. The next thing to try looks like pry bar but that seems like it could be excessive if there's something I'm not aware of...
Any advice?
Old May 19th, 2012, 09:45 PM
Squirt a bunch PB Blaster in it and let it sit 24 hours and it should let go...
Old May 19th, 2012, 10:16 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Did you try backing out the adjuster just to make sure?
Land Rover 110
Old May 21st, 2012, 10:44 AM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
I thought because it spun freely the adjuster was backed off enough. But Mike was right, I just backed it off more and it came right off.
Thanks!
brake, transmission
Turning the Brake Drum? ]-[ @ n $ Defender Technical Discussions 6 February 28th, 2012 09:26 AM
Blew u-joint in rear, help on 4 bolts removal on brake drum UpnOver Defender Technical Discussions 3 February 2nd, 2012 07:53 PM
FS Salisbury Drum Brake Parts Stmpede For Sale - Parts 3 December 18th, 2008 08:02 PM
110 drum brake shoes FS ECR For Sale - Parts 5 July 23rd, 2006 09:03 AM
D-90 rear drum brake axle assembly TDI Guy For Sale - Parts 0 November 6th, 2003 04:59 PM
» Defender Registry
Higgins
joshbova
#894
MyD90
Add your Defender
