Transmission brake assembly - Defender Source
Old July 3rd, 2013, 03:30 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
This is on a D2, I don't know if it's the same set up on a Defender, but just in case here it goes. My hand brake was seizing because lack of use, I took it apart and when removing all parts inside drum I kind of lost the detail on how the lever goes with the right shoe. There are 3 washers that goes on the pivot that keep both parts together, 2 bellevilles and 1 flat washer, anyone know the sequence and where those washers go ?
Cheers
- Charles Eames
Old July 3rd, 2013, 04:16 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Cheers
Sorry I don't know the sequence, but in the last three years I have changed 2 hand brake cables on DII's. It seems that on some years the engine earth cable comes loose, leaving the H/B cable the only path to earth. The inner welds itself to the outer so check yours.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 6th, 2013, 07:54 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Anyone with an open hand brake drum that could take a couple of snapshots ?
- Charles Eames
Old July 8th, 2013, 12:45 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Bump.
I'm stucked.
- Charles Eames
Old July 8th, 2013, 01:19 PM
A little googling turned up this page (and others)
http://www.landroverfix.com.au/land-...epair-kit.html
Old July 8th, 2013, 02:03 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I found this also but this is for a Defender hand brake. There is one for the Discovery but you can't figure out the sequence of washers from the sketch.
- Charles Eames
assembly, brake, transmission
3rd Brake Light Assembly Andrew Vick Wanted 2 February 4th, 2006 08:42 AM
lights out on auto transmission assembly cafemosaic Defender Technical Discussions 4 January 31st, 2006 01:43 PM
3rd brake light assembly, bolts for spare, 90ST cafemosaic Wanted 0 January 24th, 2006 09:23 PM
3rd brake light assembly cafemosaic Wanted 0 January 21st, 2006 10:45 AM
D-90 rear drum brake axle assembly TDI Guy For Sale - Parts 0 November 6th, 2003 04:59 PM
