Transferr case rear output seal - Defender Source
Old July 28th, 2006, 09:36 PM
redrover
Guest
Posts: n/a
Do any of you rover experts know if the transfer case rear output housing seal is the same part as the diff pinion seal? Thanks JP
Old July 28th, 2006, 09:39 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
No, it is not the same part. The OD is larger.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old July 29th, 2006, 10:55 AM
redrover
Guest
Posts: n/a
Darn. Thanks rob
Old July 29th, 2006, 03:56 PM
is that replaceable while the t-case is still in the truck? mine has really gotten leaky lately
Old July 29th, 2006, 05:21 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
My transfer case is leaking at the o-ring between it and the tranmission. Slowly keeps getting worse, so I know I am going to have to drop it soon. Just a pain in the ass. You can do the rear seal with it still in the truck.
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
rear seal is wet jblieb Defender Technical Discussions 5 September 14th, 2005 10:01 AM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
