Transfercase squeak? Please help. - Defender Source
Old April 15th, 2014, 09:26 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
1997 NAS D90 ST
Intermittent squeak coming from the transfer-case...usually in the morning backing out of the driveway, after I get going in drive it quickly goes away. It's not u-joints either. Any ideas? There has always been a considerable amount of play in the t-case. Is the t-case easy to rebuild? It only has 72,000 miles and the fluid has always been changed regularly. Thanks!!
Old April 15th, 2014, 09:30 PM
How did you determine its the transfer box?
Old April 15th, 2014, 09:33 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
That's where the squeak IS coming from. Had a buddy listen from outside the vehicle while I drove in reverse. I've been pretty sure for a while now that it was coming from the t-case but confirmed it today.
Old April 15th, 2014, 09:38 PM
RickM
Rick Mabus
95 D-90 ST
I thought I had a noise coming from my t-case also. Turns out it was the e-brake drum coming loose. It was impacted by the rear drive shaft attachment.
Old April 15th, 2014, 10:07 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Had the same issue with my 90.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old April 15th, 2014, 10:25 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
I was thinking it might be there-brake ! I'll check it out this weekend.
LT77 tranny & LT230 transfercase CDNRover For Sale - Parts 17 September 26th, 2011 10:24 AM
Yet another LT230 Transfercase!!! phoenix37 Wanted 2 February 1st, 2010 05:12 PM
Need transfercase. Can pick up at MAR ini88 For Sale - Parts 3 September 25th, 2009 01:44 AM
Is a D2 transfercase a direct replacement? phoenix37 Defender Technical Discussions 19 July 31st, 2009 07:37 AM
Transfercase noise D90user Defender Technical Discussions 4 December 4th, 2005 02:58 PM
