Transfercase noise - Defender Source
Old December 3rd, 2005, 08:24 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Transfercase noise
So after I finished up doing some work on the front end I put the tire back on the right front while it wsa still in the air and gave it a spin to hear the bearing. I heard a ratchiting sound comming from the t-case. So I started spinning the front drive shaft (diff lock not engaged) and I hear and feel a distinct ratchiting type noise and it feels like it tightnings up and then goes free as I turn it. There is some play in the u joints but not much, what is going on?
The truck is driving fine except for all the other problems
OK so... I went back out to mess around with it and I engaged the center difflock then went to trun the drive shaft and it was locked (good). But when I disengaged the center diff lock I turned the front drive shaft again and the ratcheting sound was gone...totally smooth and no ratchiting. I'm sure there was a sound, It was loud and fron the transfer case.
Rover gremlins... or something to be concerned about??
FYI I was just changing bushings and tightning wheel bearings... nothin in the drive train.
Old December 3rd, 2005, 09:04 PM
The diff lock was probably not fully disengaged. Sometimes they stick.
Old December 4th, 2005, 07:46 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Change the oil in the transfer case, see if anything bad comes out
Mike Hammond
Old December 4th, 2005, 01:46 PM
D90user's Avatar
D90user
steve
I just changed the oil a week ago, but I'll do it again. It didn't look good but no major metal to speak of. Could a partially disengeged center diff make a ratchating sound??
Old December 4th, 2005, 02:58 PM
mikeslandrover
Mike Hammond
There's a dog clutch in there I think so it could well do.
Why not drop the bottom cover plate an see what can be seen?
What did the oil look like?
Was there enough?
Mike Hammond
Transmission noise help... reb78 Defender Technical Discussions 5 September 22nd, 2008 05:28 AM
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
