Transfer Case Wont Shift - Defender Source
Old September 11th, 2006, 04:55 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
My transfer case (believed to be a 230) wonít shift out of high range. The lever moves back and forth from high to neutral and then to low. This can be done locked or unlocked it doesnít matter. When you move the shifter you can feel or what appears to be detents as its position moves from high to neutral to low. Iíve tried this stopped, rolling, engine on, engine off, 5 speed (lt77) in gear and out of gear with no luck. I havenít had a chance to remove the tunnel cover to verify linkage connection but I have lifted the boot and foam gasket and it looks like the linkage is moving and is connected.
With that anyone have any ideas.
BTW Dave from the site I havenít had a chance to open the inspection plate but will do so as time permits. Thanks again for your time on Sunday.
One last question on the top of the transfer case there are two wires that land on a spade type fitting, is this for the warning light that the t-case is locked up?
Old September 11th, 2006, 06:37 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
If you can feel the Hi/low detents, most likely the high low shift fork has come loose from the shift rod. You are probably moving the rod back and forth but the fork is stationary. There is a set screw that locates the fork to the rod that has probably worked loose and fallen out. If this is the case, then the transfer case will have to come out and the front output housing will have to come off and the center diff and gear cluster will have to be removed for access the shift fork...almost a complete teardown of the box.
The switch with 2 male spade terminals is for the diff lock light.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
