transfer case . . . transfer - Defender Source
Old September 9th, 2008, 10:15 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Any reason why the LT230 from a 2000 DII wouldn't be a drop in to my '83 110? the DII box is covered in plugs and harnesses, but I really can't think why just pulling them all wouldn't be fine. Thoughts?
Old September 9th, 2008, 11:57 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
2000 should have CDL/diff lock .. its the late 2001s, 2002s and 2003s that dont have it..
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old September 10th, 2008, 09:00 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Mid 2001 - 2003 were missing CDL.
You will still want to make sure that the case has CDL since some were replaced under warranty with non CDL units.
Old September 10th, 2008, 09:40 AM
Abrooks's Avatar
Abrooks
Tony Brooks
This one appears to have the CDL -- apparently it was replaced due to a leaking input seal by the owner -- 75K on it. I honestly didn't realize that there could be that many electronics hooked up to a transfer case . . .
ID:	15190   Click image for larger version
ID:	15192   Click image for larger version
Old September 10th, 2008, 09:46 AM
rmuller
Ryan
Yup, thats the cdl right on the first pic.. nice and clean case!
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old September 10th, 2008, 10:39 AM
You need a DII front drive shaft or to switch out the flange.
Old September 10th, 2008, 10:46 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Easy enough to swap out the my flange, thanks!
Old September 10th, 2008, 01:20 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Save the flange and then keep an eye open for a cheap / free DII front driveshaft that needs rebuilt
Old September 10th, 2008, 01:25 PM
rmuller
Ryan
you can try asking at the dealership too.. they usually just replace the whole shaft under warranty and scrap the old ones..
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old September 10th, 2008, 03:15 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Ummm...that DII driveshaft that I had that we exploded on your workbench is all yours if you want to get it rebuilt...
Old September 10th, 2008, 03:19 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks I may take you up on that! I still need to find that data on the parts to rebuild the middle . . . cardon(?) piece. anyone have any experience here? The shaft in question needs ujoints (easy enough) but also needs the center pivot piece rebuilt.
Old September 10th, 2008, 03:28 PM
rmuller
Ryan
precision 617 is the centering kit or Neapco 7-0081NG
the u-joint is precision 344 or pdq1 0005 or neapco 1-0005
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old September 10th, 2008, 03:31 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Outstanding, thanks!
Old September 10th, 2008, 05:50 PM
I have about 4 or 5 of them available for rebuild.
Old October 2nd, 2008, 08:30 PM
Abrooks's Avatar
Abrooks
Tony Brooks
This case has been procured -- what if any of the harnesses do I need to keep? I think this case has more wiring than the rest of the 110 in total!
Old October 3rd, 2008, 12:04 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Good call, thanks. Apparently it needs a new input seal -- while I'm at it, any suggestions for other seals to replace?
Thanks again!
Tony
Old October 5th, 2008, 03:47 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
It fits just fine- did it this summer when my transfer box went west whilst in Morocco. Limped to Southern Spain and changed it out foe a DII 1:1.211 ratio box. I ignored all the wires apart from the difflock light and it worked just fine, The ration was a little high compared to the 1:1.444 that was in there before.
Mike Hammond
Old October 5th, 2008, 10:43 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks Mike. When you say it was a little high, how would you discribe driving it with that ratio (I'm going from a 1:6)?
Old October 5th, 2008, 12:20 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
On the road from a 1.6 to a 1.2 you will notice it has less power when you take off but when you are on the highway your rpms will be lower and you will be able to obtain a higher top speed than with the 1.6
In low range you should not notice a diffrence since they have the same low range ratio.
Old October 5th, 2008, 04:13 PM
mikeslandrover
Mike Hammond
Well on some really steep hills going up to Granada I was down into 3rd with my foot on the floor, but mostly it's good. I have to hang onto the lower gears a little longer, cruising is much more relaxed, 70 mph all day crossing France and Spain this summer. Its about an 18% increase over the 1.44. and about a 38% increase over the 1.666.My engine is standard. it pulls OK but I wouldn't want to try towing at the max stated weight of 3.5 tonnes with the 1.211 transfer box. The fuel consumption seems unchanged. at around 30mpg (imperial). I run 235/85R16 grneral TR's.
I'm surprised you haven't thrashed the 300 tdi to death running that ratio transfer box. What was your cruising speed?
The difference will be like chalk and cheese, you'll wonder how you lived with it before. Be careful though, you'll arrive at your first few corners 20 mph too fast.
Mike Hammond
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
