transfer case . . . transfer - Page 2 - Defender Source
Old October 6th, 2008, 11:39 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Originally Posted by mikeslandrover
I'm surprised you haven't thrashed the 300 tdi to death running that ratio transfer box. What was your cruising speed?
The difference will be like chalk and cheese, you'll wonder how you lived with it before. Be careful though, you'll arrive at your first few corners 20 mph too fast.
The truck is new to me and the transfer ratio was hell -- top speed of 60 or so. It also over taxed the already failing radiator, which is now with Pendy to be built into a full-width with a full-width intercooler in front and a standalone oil cooler. My hope is that with all this and a the 1.2 xfercase that's going in I should be fine for highway driving.
going to start stripping the new case tomorrow.
Old October 7th, 2008, 09:45 AM
Make sure you remove the solinoid for the shift interlock.
Old October 7th, 2008, 04:34 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Errr.... which one is that? I just stuffed the replacement one and drove off into the sunset, literally.
What do I need to remove, what's going to occur because I haven't
Mike Hammond
Old October 7th, 2008, 04:36 PM
Not sure if it is on a DII case, I think it is, but it is the round tube structure on top of the case with the wire coming out of it. There is a solinoid to prevent you shifting from high to low unless you are in neutral.
Old October 7th, 2008, 04:38 PM
mikeslandrover
Mike Hammond
Are you tweeking the fuel pump?
Hmm... so if it's not wired up it shouldn't do anything?
Mike Hammond
Old October 7th, 2008, 04:57 PM
If it is not wired up you cannot shift into low at all.
Ron
http://www.expeditionlandrover.info/...n_gearbox2.jpg
It is in the round thing on top.
Old October 8th, 2008, 02:14 AM
mikeslandrover
Mike Hammond
Yep .... that's the bit on top, someone must have disabled it before I got the transfer box. It's not wired up but I can select low range. I feel a little ivestigative spanner work is in order this weekend
Mike Hammond
Old October 8th, 2008, 09:38 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Mike, yes, I'm going to turn up the fuel a bit to take advantage of the intercooler.
Ordered the seal kit RTC 3890 for it, any pointers on it. This is my first time messing around much at all with the transfer case, so all of the help is much appreciated.
Tony
Old October 8th, 2008, 12:42 PM
mikeslandrover
Mike Hammond
check the drive flanges for a groove where it runs in contact with the seal, that's where the leaks occur. you can polish out a slight groove. also you can adjust there the seal sits slightly.
Mike Hammond
Old October 10th, 2008, 03:03 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Tony
I'd open it to make sure everything looks fine in there (no chunck of metal and other foreign object).
As long as you don't start disassembling the gears / splitting the case in half (should I say "third"? ;-) ), you can't do much arm.
I'd replace input and output seals all around just because you have it out!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 10th, 2008, 04:36 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Good ideas, thanks. The seal kit appears to be very comprehensive, I'll replace as many as I can identify. Loic, I'll absoutely pull the inspection plate, good call! Ray and I are tackling this on Sunday, we'll report back afterwards. Unless we really eff up, in which case you won't hear another word about this . . .
Old October 11th, 2008, 12:06 AM
Whats up with Rays rig ? Head gasket ? Liner slipage? Do we need to pull it apart ?
Old October 13th, 2008, 10:39 AM
Abrooks's Avatar
Abrooks
Tony Brooks
With a lot of help from Ray, we got the case resealed (save the PTO cover and cracking it in half), pulled the inspection plate (looked perfect) and removed the solenoid. Took all of an hour including several beer breaks. Now to get it installed.
Old October 13th, 2008, 11:31 AM
MonLand
Loic Fabro
Make sure you use a transmission jack to re-install it or you have a good chance of messing up the seals (those suckers are not heavy duty! ;-) ). But I'm sure you knew that already.
Sounds like you guys had fun!
Before I forget: I bought (can't remember where.... RN? EE?) plugs to put on the diff case/transfer-case/etc with a magnetic bit that, I think, will help in the long run. Since yours is likely without oil right now, then.... you might want to do that too?!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 13th, 2008, 05:23 PM
Ray_G's Avatar
Ray_G
Ray Gerber
My rig is likely on the way to either the head gasket needing to be replaced (again) or a slipped liner-but the bigger issue at hand is that I don't intend to deal with it since we were already going down the diesel path anyway, this just gives another reason to push that along. Since A procured herself a MB 300D as a DD we're rolling three cars-hence Tony rocking the Disco for a bit while the 110 waits to be upgraded and returned to the road....hopefully the Disco doesn't blow up on him between his house and Clarendon.
Change the seals on the TC was interesting-that thing clearly was in a DII that never went off road. Tony did all the work, I put myself in charge of drinking most of the beer.
Old October 13th, 2008, 05:47 PM
Ray,
Diesel disco or defender ?
Old October 13th, 2008, 05:55 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Loic, it already had a magnetic drain plug!
Old October 13th, 2008, 06:37 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Doug-
Diesel Disco...at this point I've got enough into that truck (and enjoy it's quirks) that I want to follow that path. The Defenders are sorely tempting but I'm 99% sure I'm sticking with Coyote.
r-
Ray
Old October 20th, 2008, 09:04 AM
Abrooks's Avatar
Abrooks
Tony Brooks
There's a thread on discoweb (http://www.discoweb.org/forums/showthread.php?t=53043) that is currently discussing the inability of the later LT230s to fit onto early auto boxes (the thread is specifically referring to D2 xfer cases fitting onto earlier RRCs). So just to revist post #1 of this thread (and to avoid considerable stomping of feet in the future): is there a spud shaft length issue in fitting a D2 LT230 onto a 300tdi R380?
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
