Transfer case shiftlock - Defender Source
Old July 27th, 2008, 09:07 PM
wingnut
Scott Launer
97 D-90 SW
Howdy all.
Have a 1997 SW. Havent driven it a lot in the last year or so. Checked all fluids and started driving it again. A few days later went to shift into 4-Low. No go. Wont shift out of 4-High. Diff lock works fine. I've pulled the tunnel cover out and checked and regreased all the linkage. Lever moves fine with the linkage detatched from the t-case end of the 4-High/Neutral/4-Low switch. Went through the shop manual and found that there is a shiflock that keeps the t-case from shifting into neutral when tranny is in gear. So...I pulled the shiftlock solenoid out and the t-case shifts fine now. Watching/feeling the solenoid when shifting the D in and out of gears results in no movement of the plunger. There is little to no info on the 'net regarding these little buggers. So questions abound:
Anyone know if there is a fuse and/or a relay that serves the shiftlock solenoid? Can't seem to find one that is obviously marked nor is there mention of either in the service manual.
I did see one blog about someone with a RRC just removing the plunger from the solenoid and calling it good. Any comments on doing the same for the D? Will that result in a permanenet check engine light?
I presume the plunger would be in a 'locked' state until the tranny is shifted into neutral at which point it would unlock (plunger retracted). At that point the connector should measure some voltage, yes?
Insights or thoughts on anything I havent yet checked is greatly appreciated!
Thanks!
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
