transfer case reseal HELP! - Defender Source
Old December 8th, 2008, 03:07 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
I just had my '94 d-90 at the dealership because of a leaking transfer case, they said I needed to do all the seals in there. $84 bucks for the parts. $1300 for the labor!
I was wandering if there was anyone in the vicinity of Erie, CO that would be able to help me with doing this job one of these weekends. i would like to do it myself, but have no confidence in doing it without a little guidance.
thanks!
Old December 8th, 2008, 03:13 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
If you get me a plane ticket I'll come help...anything to get back to CO! haha
Seriously though, it isn't too hard, but is easiest with two people to help line everything up when you put the two halves back together. The input and output seals are a piece of cake too. I'm sure you can find someone out there that would be willing to help you out. The hardest part will be taking the t-case out if you don't have a lift, but it probably still won't be that big of a deal.
Old December 8th, 2008, 03:20 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
I don't have a lift at my disposal... Thanks for the reply! I would still want some help if there is anyone in CO that is willing
Old December 8th, 2008, 03:25 PM
Buy used T-case, replace input seal, put in used t-case, sell leaking t-case.
Old December 8th, 2008, 03:34 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
that sounds more expensive ??
Is this the kit that I need to buy?
http://www.roversnorth.com/store/p-5...30-trnsfr.aspx
Old December 8th, 2008, 03:48 PM
That would do it.
Ron
Old December 8th, 2008, 06:13 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
The dealers just seal them with right stuff. All you really need are the input and two output seals. The case half you can just use the right stuff. The other areas don't generally leak, but if the large square access panel is leaking you can seal that with right stuff as well.
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
