Transfer Case Rebuild - Defender Source
Old July 18th, 2010, 01:45 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I need to swap out my Disco 1.2 t-case for a 1.4. Can I keep my current case and just swap over the gears? The donor t-case is a Defender t-case, so different linkages, etc.
Semper Fi!
Old July 18th, 2010, 02:05 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
mind if I ask why you're making the change?
George
Old July 18th, 2010, 02:13 PM
Wolf Fabrication
Sterling Archer
'08 D3
My truck has a Disco 1.2. The proper t-case for a 200tdi 110 is the 1.4. I just installed some larger tires and now really need the extra 'ooompf"
Semper Fi!
Old July 18th, 2010, 02:48 PM
Gkase's Avatar
Gkase
George Kase
Im just about to put a 1.2 disco into my 83 with 200tdi...i'll be using stock tires and mostly street and highway...
how did it drive without the big tires on it? I've got the 1.6 in there now and its tough getting over 50mph...I was hoping this would make it drive more like my D90...
Old July 18th, 2010, 02:55 PM
Wolf Fabrication
Sterling Archer
'08 D3
I think you'll be okay if you stick to stock tires, but others might have a different opinion. My truck had 33s on it and was sluggish leaving the starting line on a hill, but could cruise fine on the highway. I now have 35s and the gearing is off.
Semper Fi!
Old July 18th, 2010, 04:14 PM
Gkase's Avatar
Gkase
George Kase
Thanks for that info!
Old July 18th, 2010, 04:38 PM
Linkage should be basically the same b/w a DI and a D90 t-case.
Old July 19th, 2010, 07:39 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
It should just swap no problem..
Legend in My Own Mind.
Old July 19th, 2010, 07:51 AM
Wolf Fabrication
Sterling Archer
'08 D3
Good to hear, I now have the gears and will do the swap this weekend. Anyone have any tips? I've done plenty of Jeep and Willys t-cases, how hard are the LRs?
Semper Fi!
Old July 19th, 2010, 08:31 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Have the seal kit along with a new crush sleeve and nut for the intermediate shaft... simple
Old July 19th, 2010, 08:34 AM
Wolf Fabrication
Sterling Archer
'08 D3
Happen to have those part numbers?
Semper Fi!
Old July 19th, 2010, 05:12 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
i will get them later for u
Old July 21st, 2010, 01:58 PM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
good article in June issue of Land Rover Owner on how to do this, pictures and all.
keith
...you'll feel better in a couple of days.
rebuild, transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
