transfer case questions HELP! - Defender Source
Old June 14th, 2004, 07:30 PM
mattwhite
Matt White
94 D-90
Ok for months now, I have been searching and waiting to get a LT230T transfer case and now I'm at my limit and something needs to get done.
Question: I have been under the impression that a '94 d-90 with a r-380 can be fitted with only a LT230(T) case, and that the LT230(Q) will not work.
A friend recently told me that if I changed the input shaft spines to the transfer case I can fit the LT230(Q)?
Matt
Old June 14th, 2004, 08:05 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Matt,
The LT230Q box will bolt up to your R380 with no problem. The automatics require updating the output shaft when switching the 't' for the 'Q'. The issues you may encounter would be having to remove the interlock solenoid, possibly blanking off some unneeded sensor holes, and possibly changing the front output flange and the rear output housing if the 'q' box in question came out of a DII. But any LT230T or Q will bolt to your R380...it's just a matter of configuring it to your requirements. Just out of curiosity, why is it taking so long to find a t-case?
Rob Dassler
Old March 8th, 2009, 02:45 PM
Departing90
Sasha
95 D90
http://www.defendersource.com/forum/...29&postcount=1
transfer case
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
