Transfer case plugs calls for hylomar. is there a substitute? - Defender Source
Old June 21st, 2016, 02:41 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
I searched but couldn't find any info on this...
I'm looking to change the transfer case fluid on a 1997 NAS D90. It's said the need to apply hylomar to the drain & fill plug threads. Is there a substitute that can be used in place of hylomar, that is easy to source at local autozone/pepboys/etc?
Thanks!
Old June 21st, 2016, 05:01 AM
Amazon!
Old June 21st, 2016, 07:44 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Teflon tape.
Old June 21st, 2016, 07:55 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I don't think I ever applied anything on mine. This is a tapered thread and should be self sealing (don't tighten it too much or you'll destroy the thread).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old June 21st, 2016, 08:10 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Permatex/Hi-temp RTV silicone gasket maker 81160- ReadReviews onPermatex #81160
I used this and had no issues.
Old June 21st, 2016, 08:14 AM
Naplm00
Matthew
Arp thread sealant
Old June 21st, 2016, 09:16 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^^ This. ^^
I've never applied anything and this is the LAST place that will leak....
Rent my
Old June 21st, 2016, 09:26 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The plugs are an interference fit. The threads seal against themselves, the teflon tape only acts as a lubricant.
Old June 21st, 2016, 09:44 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
My new ashcroft R380 weeps around the fill plug after torquing it to the correct spec. I imagine I have a hair too much fluid in there, but want to do something about it as well.
Old June 21st, 2016, 09:46 AM
Just look for thread sealant at the auto parts store. Don't use teflon tape.
Old June 21st, 2016, 02:25 PM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
I've had good luck just putting a dab of Loctite Blue thread sealer - something I always have around...
Old June 21st, 2016, 06:22 PM
lithium1330
'97 SW NAS 4.6
And do you guys replace or reuse the copper washer for the drain plug?
In other cars, I've replaced but also reused without issue.
Old June 21st, 2016, 06:43 PM
Naplm00
Matthew
I reuse if it's not crushed to shit and dicked up. The lr copper washers kinda suck anyway, most of the time when mine are shot I replace them with a universal thick copper washer from the hardware store
transfer case
When duty calls... Cube II Misc. Chit-Chat 11 June 4th, 2010 10:57 PM
Subsitute fir Hylomar? Grover Defender Technical Discussions 2 November 4th, 2008 10:30 AM
Valley Gasket/Water Pump--Right Stuff or Hylomar? Grover Defender Technical Discussions 2 October 25th, 2008 05:38 PM
Oil Pan Re-seal- Hylomar or Right Stuff? Grover Defender Technical Discussions 7 October 1st, 2008 02:01 PM
Drop calls - AT&T Samsung Blackjack themaxx Misc. Chit-Chat 2 February 21st, 2008 10:42 PM
» Defender Registry
#894
MyD90
110
RedRover02
Add your Defender
