transfer case linkage - Defender Source
Old May 10th, 2006, 12:01 PM
WestTexasDefender's Avatar
WestTexasDefender
Sam Allen
'97 LE #234
Is there a way to adjust the t-case linkage? Mine has always been real stubborn on getting it into low and back into high. I'll be getting my cv joint in today so the d is gonna come back to life and want to fix this if possible.
Old May 11th, 2006, 01:16 AM
Shane@EVS
Roverhybrids
It is adjustable but I don't know if that is your problem..I would maybe recommend you lubricate it.
Old May 11th, 2006, 09:34 AM
I agree, pull the center console out to get a better view of the linkage and spray it down and move it back and forth a bunch. They get bound up when they don't get used much, i recommend cycling it at maybe once a week until it starts moving more smoothly, then once a month should be enough to keep it working proper.
Old May 11th, 2006, 10:47 AM
WestTexasDefender
Sam Allen
'97 LE #234
Ok yea the guy that had it basically stopped using it that's why he sold it so i guess he negleted a few things. This is gonna make me sound like i'm a idiot but how do you remove the center console? And just any kinda lubricant should work?
Old May 11th, 2006, 04:57 PM
OK you have a 97 with an auto, so I don't know how it comes out, not sure if it is all that easy either. But you can crawl under the truck, have someone else push the shifter back and forth so you get an idea what to squirt, then hose it down with WD40 to clean it all up and get it working well.
Old May 11th, 2006, 07:22 PM
WestTexasDefender
Sam Allen
'97 LE #234
I went out to my barn to look at it and i should be able to get it off ok. I was just wondering if the were some hidden bolts like always on the defender . Well i'll be getting this done this weekend since my cv joint won't be in till saturday
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
