Transfer case leak - through trans brake drum - Page 2 - Defender Source
Old July 2nd, 2012, 11:15 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
120 lbft
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 6th, 2012, 01:55 PM
Follow up stupid question as I plan to tackle this over the weekend.
I left both my flange puller (where you screw the bolts I to the flange) as well as my pitman arm puller (that has the arms that go on each side of the flange) in VA by accident. So I need to borrow one. When I did the front pinion seal and rear Salisbury seal I used the arm puller to get the flange off in both cases
So question is - which one do I need to remove the output flange on the transfer case?
Old July 6th, 2012, 02:52 PM
Naplm00
Matthew
puller is not required, I did mine without.
Only the dust shield needed and real effort, i ended up heating it with a hot air gun and it came right off. did the same to put it back on.
The flanges with the massive nut off just slide onto the shafts
Old July 6th, 2012, 03:38 PM
Awesome, thanks Matthew...that was sort of the experience I had with the front pinion on the 90, but the rear Salisbury was something that needed the "big guns" so figured I'd check first.
Old July 6th, 2012, 04:32 PM
Clean out the breather. Leaks that bad are usually either a plugged breather or a bad bearing in my limited experience.
Old July 6th, 2012, 06:05 PM
There's a breather on the transfer case? I honestly did not know that...where is it located?
Old July 6th, 2012, 06:16 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Mine was on top. It's an LT95 though:
http://www.defendersource.com/forum/...&postcount=176
MUDSUX
Old July 6th, 2012, 06:20 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Right in the center of this pic on top of the case.
Name:	T-Case Breather.jpg
Old July 17th, 2012, 04:35 PM
Finally took this thing apart today...main nut was literally able to be removed by hand, obviously things were a bit "loose" in there. No significant wear on the flange or output shaft, so going to clean up and put in new seal/felt/nut, torque to 120ft-lbs, and call it a day!
Old July 17th, 2012, 05:07 PM
Leaks from the u-joint side are from the felt seal, in this case from a loose nut. Shaft seal leaks should come out behind the brake back plate as there is a leak catcher that diverts the oil through a hole in the plate.
brake, transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Need a Transfer case skibigwest Wanted 2 February 1st, 2006 12:48 AM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
