Transfer case leak - Defender Source
Old May 22nd, 2012, 07:01 PM
Transfer case leak
So, changed my oil yesterday and got ambitious and pulled my inspection cover off the transfer case to reseal it thinking there was a small chance that's where my leak may be coming from. Resealed the HELL out of it...turns out was not the leak (which I sort of suspected it was not).
Anyhow, here's some pics...appears to be coming from up past the red arrow, following the red line down and dripping off the bottom inspection cover bolt. Anyone have an idea of it's origin that's dealt with this before? It's not the end of the world, I top up at oil changes or before wheeling but would like to stop the drips on my driveway/garage if possible (and not a pain in the arse to fix).
ID:	52013   Click image for larger version
Old May 23rd, 2012, 03:13 PM
Mogly406's Avatar
Mogly406
Jay
'62 IIA 109 coil sprung
It looks like your leak is coming from the intermediate shaft. Sometimes just replacing the o-ring will fix it, but often times the hole in the aluminum casing becomes oval and needs to be sleeved. Lots of good info in the following link. There is a lot to read, but there is intermediate shaft leak content...
http://forums.lr4x4.com/index.php?showtopic=48673&st=20
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer Case Overfill D90user Defender Technical Discussions 19 May 10th, 2005 01:51 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
