Transfer Case Flange Removal & Bolt Replacement - Defender Source
Old October 17th, 2014, 11:18 AM
mattarm's Avatar
mattarm
Matt
1993 D110
I have a new to me transfer case which appears to have stripped, cross-threaded and bent bolts on the output flanges. At first look it appears that I can just remove the large self locking nut, slide the flange out and swap the bolts, replace and secure nut. Is it really this simple? What I don't want to have happen is it remove the nut and pull on that flange and things go sideways.
I assume I will need to replace the self locking nut and the felt washer. Anything special about either? Does anyone happen to know the size of both the felt washer and the self locking nut?
Old October 17th, 2014, 11:23 AM
Yes, it is that simple. Undo large but, pull flange off by hand. Be aware some oil will come out. You might want to replace the seals at the same time, and yes, the nut and felt washer. The nut is a normal M20 nyloc nut. Make sure the nut is properly torqued. They like to come loose.
Old October 17th, 2014, 11:38 AM
The bolts are regular 3/8" x 1-1/4" UNF as well with nyloc nuts if you want to source locally. Always keep a good supply of 3/8" UNF nuts on hand...
Old October 20th, 2014, 03:01 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Many thanks to all for solid, useful info.
ac, transfer case
Nylock nut size, rear flange of transfer case - also identify T-case ratio hillstrubl Defender Technical Discussions 3 July 11th, 2012 02:42 PM
Mystery bolt on the transfer case cbass Defender Technical Discussions 3 October 30th, 2010 01:32 AM
Transfer Case Filler Plug removal d90xjay Defender Technical Discussions 19 December 29th, 2009 12:56 PM
Muffler Flange Bolt removal Bozman Defender Technical Discussions 2 May 28th, 2009 06:43 PM
transfer case . . . transfer Abrooks Defender Technical Discussions 38 October 20th, 2008 09:04 AM
