Transfer Case Filler Plug removal - Defender Source
Old September 16th, 2007, 10:53 AM
d90xjay's Avatar
d90xjay
J Phillips
1997 D90 SW
I'm having a very hard time removing the transfer case filler plug. I have tried and tried to remove the plug, even taping the rachet a few times with a big hammer, and I cant get it to budge. I don't want to break the plug or crack the T-case wall. Are these things that hard to remove. The last time the fluid was changed was by the PO at the LR dealership.
Old September 16th, 2007, 10:55 AM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
have you soaked it liberally in liquid wrench or pb blaster?
Old September 16th, 2007, 10:57 AM
They arent hard to remove per se, but monkey techs tighten them up ridiculously over tight. Since its a 1/2" drive, just try a breaker bar and pull gently.
Old September 16th, 2007, 02:42 PM
d90xjay's Avatar
d90xjay
J Phillips
1997 D90 SW
No I havent tried soaking yet. I will give that a try. I notice that the LR Workshop manual says to use Hylomar sealer on the treads when putting the plug back in. I have feeling it was way too much thread sealer and overtightning from the dealer. Thx for the suggestions.
Old September 16th, 2007, 10:24 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Once you have tried soaking it in liquid wrench and other (stronger) PB Blaster, used a long breaker bar, then you can try to use a impact wrench (use the lowest strength first).
If you use the impact wrench, stop using it and revert to a regular (manual) wrench as soon as the plug turned by 1/4th of turn or you will risk messing up the thread.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 17th, 2007, 02:04 AM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Might also try heating it if someone happened to put red Loctite on it.
Old September 17th, 2007, 04:52 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
It should come out fairly easily with a 2 ft. breaker bar or torque wrench. A short rachet? Maybe not so easy.
Since the threads are in constant contact with oil (on the inside), I don't think hitting it with PB Blaster, etc., will do much of anything.
Old September 17th, 2007, 08:10 PM
Heat it up. The aluminum will expand more and let it lose.
Old September 17th, 2007, 10:22 PM
d90xjay's Avatar
d90xjay
J Phillips
1997 D90 SW
I got a breaker bar, been using that along with a hammer. I picked up some PB blaster today, and going to keep spraying it this week, and try again this weekend when I have more time.
Old September 18th, 2007, 09:53 AM
MonLand
Loic Fabro
It's a hole.... It you heat up the aluminium around the hole, the hole will become smaller as the aluminium expands..... I think the idea of heating it up is to cause the heat on both to make the thread "move" between the two metals/break any sealant that might be there, hoping that this might help.
Technically, what you really would mean to do is cool the filler plug so that it becomes smaller (and cool the T-Case).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 18th, 2007, 10:39 AM
No, the hole will become bigger. This is the law of physics. Go grab a caliper and try it yourself on something.
Since the aluminum expands more than the steel, it will release.
Old September 18th, 2007, 10:51 AM
MonLand
Loic Fabro
Yeah, that makes sense. I don't know what I was thinking.... Probably lacking sleep!
Thanks for correcting me.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 18th, 2007, 12:48 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Put your foot on that breaker bar.
Old December 27th, 2009, 07:09 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
seems the best place to place this issue....when putting my drain plug back in it broke (just regular one handed socket tightening, no huge pull). Please tell me I am not totally screwed (no pun intended). Since I was running out of daylight I will have to survey more tomorrow, but how accessible are the drain plug 'remains' if I remove the plate and take a go from that angle? Didn't seem too far. Are my threads permanently damaged? A whole new XF case can't be the solution. Not leaking with the small bit of oil I put in. Thanks for the help.
Inspirational Thought of the Day
Some people are like Slinkies ...
Not really good for anything, but they still bring a smile to your face when
you push them down a flight of stairs.
1995 Discovery
Old December 28th, 2009, 10:07 AM
Weird. Never heard of that before. It just cracked? The bottom plate should be easy enough to remove, but the bits might not have made it all the way to the bottom. You might have to (or be better off) fish the bits out through the hole where it threads into depending on how big they are. Just make sure you get them all. A flashlight should make the job easier.
Old December 29th, 2009, 01:06 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Yeah, it happens. The drain plugs are hollowed out where the magnet is inserted. They are prone to cracking the threads and breaking off. You aren't screwed. Pull the cover & punch out the magnet and use an easy out to back it out, run a 12x1.5mm tap through the threads, and replace the plug. If the threads in the t-box are damaged beyond salvage you can drill and retap it for a 14mm plug. If you drill it oversize, make sure to drill the hole squarely with the case, otherwise the sealing washers don't seal so well. Look through the NAPA parts & accessories catalog...they have a whole section of drain plugs.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 29th, 2009, 01:18 AM
I see now. Drain plug, not fill plug. DUH. All makes sense to me now.
Old December 29th, 2009, 05:28 AM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
whew. Good to hear. Just went to the top of the list of things to do on this three day weekend.
1995 Discovery
Old December 29th, 2009, 10:35 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
Go easy on that hammer, should come out with a breaker bar. Or try a longer breaker bar. And remember righty tighty lefty loosy.
Old December 29th, 2009, 12:56 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
I wish it was something that 'manly'.....straight regular tighting. I'm left handed so I have to be extra careful which way I turn all the time. And I get it wrong a lot still
1995 Discovery
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer Case Overfill D90user Defender Technical Discussions 19 May 10th, 2005 01:51 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
