Transfer case fill plug - Defender Source
Old February 20th, 2013, 09:40 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Does anyone know where I can get a T-case plug that's like a pipe plug, you know, with the protruding square that you can put a Crescent wrench on ? I'm tearing the hell out of the covering to the E-brake pull cable housing cover using a 1/2" drive breaker-bar ? Are the threads on the T-case NPT pipe threads ?
Old February 20th, 2013, 09:52 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Like this? RovahFarm has them, $6.99
-Ren Ching
Old February 20th, 2013, 09:58 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Originally Posted by SMOB View Post
Like this? Rovah Farm has them, $6.99
THANKS !!
That is exactly what I want & I love doing business with Trevor. I think I'll replace all 3 & get a spare to boot !
Old February 20th, 2013, 10:07 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Use a pipe, but don't smoke it!
Does anyone know where I can get a T-case plug...I'm tearing the hell out of the covering to the E-brake pull cable housing cover using a 1/2" drive breaker-bar ? Are the threads on the T-case NPT pipe threads?
Common part and if it's too tight...
Put a pipe on the end of the 1/2" breaker bar to get the plug out.
This may require you to get it up on a lift for clearance issues.
Obviously some chucklehead torqued it like ten men tight!
Over tightening is a common problem.
A tapered steel pipe plug will cut it's way into a softer aluminum casting rendering the hole bigger or even too big.
Assuming the plug is out...
Wrap the plug in a plumbers type tape and after the T-case if full of fluid screw the plug in until it is as tight as you think it should be but not too tight (25lbs torque will work).
If the plug keeps going in stop when it is flush with the casting.
Then clean the outside of the area where the plug and the aluminum meet with thinner and wipe clean.
Then spread some silicone black silicone sealer over the seam between the plug and the T-case housing.
Good to go, bro!
RDavisinVA
transfer case
Transfer Case Drain Plug Problem kzack Defender Technical Discussions 10 October 21st, 2010 08:14 AM
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer Case Overfill D90user Defender Technical Discussions 19 May 10th, 2005 01:51 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
