Transfer case dilemna- No numbers! - Defender Source
Old March 28th, 2012, 10:39 AM
winn442's Avatar
winn442
Winn Bearden
I've got a feeling that my Td5 has had an older 1.6 box swapped in for the 1.4
1) Doesn't have the hi/lo switch for the computer to change gas pedal throw (connector just hanging)
2) A ground wire for the difflock switch still on box (Td5 feeds the switch hot)
3) I'm in 5th before 30 MPH!!!!
There is not a number on the box anywhere where it should be, nor any indication that a number has been removed.
Is there any way to tell what the ratio is, or a serial # anywhere else than the normal places? Or will I have to remove covers and start counting teeth?
Winn Bearden
Old March 28th, 2012, 11:06 AM
grnrvrs's Avatar
grnrvrs
Paul
88
5th gear, 30mph, at what rpm? Are you sure you're not in low range?
1970 SIIA 88, Sold
Old March 28th, 2012, 12:07 PM
winn442's Avatar
winn442
Winn Bearden
If I had a tach I could use the calculator on Ashcroft's website to see what I had......
Going to try my scanner tonight, plug it into the OBDII port (it's not OBDII but the plug is the same) and see if I can get a rev count
Winn Bearden
Old March 28th, 2012, 01:15 PM
on the early boxes the numbers are on the side not on the back. helps to have a mirror to read them.
Old March 28th, 2012, 08:03 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
5th and only going 30 mph, your in low or something is wrong?
Land Rover 110
Old March 29th, 2012, 08:06 AM
winn442's Avatar
winn442
Winn Bearden
Guys, I'm not in low....maybe 30 is exaggerating....casually going through the gears it's more like 35....this thing has so much low end now that it's got a Dastek chip, boost box, huge intercooler, egr removal, and straight exhaust...I could change it at a higher speed easily, I just don't rev it up through the gears unless I need to.....60 seems to be the "sweet" spot, at 70 it feels over-reved....and I'm running 35's.....can take off in first without any pedal at all, and can take off in second if I'm not on a hill.....
I've looked EVERYWHERE for a number where it should be, old and new....going to take the skidplate off this weekend and look some more....got a feeling I've got a 1.6 box though.....
Winn Bearden
Old March 29th, 2012, 08:52 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
May want to check the diffs as well, maybe someone put 4.10 or 4.75 gears in there?
Pretty easy to check
Old March 29th, 2012, 11:10 AM
winn442's Avatar
winn442
Winn Bearden
Just had them out when I put in ARB's....didn't cross my mind to count teeth....been in enough of them that it seems I would have noticed if they weren't 3.54's....
Winn Bearden
Old March 29th, 2012, 12:03 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Let us know what you figure out. Seems like pictures could make this post a sticky for other owners like you that come into a similar problem.
legend in my own mind
Old March 29th, 2012, 03:43 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Fwiw winn442 you do not need to take anything apart to check the gear ratio in the diff you can use the old spin the tire and count how many times the drive shaft rotates. Free and easy to check.
http://www.jedi.com/obiwan/jeep/misc/gearratio.html
Old March 29th, 2012, 04:28 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Even with a 1.6 box you could not do fifth before 30mph without a lot of stumbling. Just b/c it says Hi with the lever back doesn't mean that it's high range...
http://www.ashcroft-transmissions.co...d&productId=45
Videos of where to find the serial number and list of corresponding numbers to ratios at the bottom.
You little rebel, I like you.
Old March 29th, 2012, 06:50 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Winn - your description sounds very familiar. With 33s and the stock 1.4 T-case, 55 was my 'sweet spot' and definately thought it was over-reving on the highway at 70. And I'd idle up my driveway in 1st. Switched to a 1.2 - much better. Regardless if you have a 1.4 or 1.6, I'd start looking for a 1.2 T-case. Mark
Old March 29th, 2012, 07:48 PM
Use to drive two Discos one auto the other 5speed. The 5speed had been fitted in the factory with 1.4 and boy was it fun.
Old March 29th, 2012, 07:54 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
I have no experience with a Td5, but fwiw, just read this http://www.defendersource.com/forum/...8&postcount=14 after reading the above.
Old March 29th, 2012, 08:12 PM
Winn, I have a spare 1.2 you could borrow... Low miles too.
Old March 30th, 2012, 03:01 PM
winn442's Avatar
winn442
Winn Bearden
Scott, might take you up on that, Dempsey has a 1.2 case out of an old RRC that we were gong to swap, doesn't matter to him what case he has, it'll be in that Peguoet power buggy he's building...it'll never see high range....is your box a Q box?
Winn Bearden
Old May 7th, 2012, 08:10 AM
winn442's Avatar
winn442
Winn Bearden
Swapped out the old leaky 1.6 case yesterday for a 1.2. What a difference! Have to learn how to drive it again, before I could take off from a stop without having to give it any pedal, now I have to give it a little. On the interstate this morning on the way to work, 70MPH was SWEET!!!! The Q box is a lot quieter too.
Winn Bearden
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
