Transfer Case "Clatter" - Defender Source
Old August 29th, 2010, 10:49 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Just installed a newly re-geared t-case. Swapped from 1.2 to 1.4 gears. I now have a "clatter" when I let off the accelerator pedal. I assume this might be the difference between my old gears meshing with the new 1.4s. I did adjust the end lash on the intermediate gear per the manual.
Any ideas?
Semper Fi!
Old August 29th, 2010, 11:14 AM
dchapman
Daniel Chapman
1999 D1
Sounds like the lash is not correct. Too much slop. The "clatter", or any noise, is not normal.
Old August 29th, 2010, 11:29 AM
Wolf Fabrication
Sterling Archer
'08 D3
I agree, it's not normal. How is the lash adjusted in the LT230? The manual makes no mention of adjusting any lash, only the end lash in the intermediate gear.
Semper Fi!
Old August 29th, 2010, 01:43 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
are the taper roller bearings good? There's a crushable distance piece between them. If it's too crushed then there's clatter and it's not good for long and trouble free motoring
Mike Hammond
Old August 29th, 2010, 02:06 PM
Wolf Fabrication
Sterling Archer
'08 D3
New bearings, races, and crush sleeve, torqued to specs.
Semper Fi!
Old August 29th, 2010, 03:08 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
I had the same problem when I switched input gears from the early solid one to a latter cross drilled version. I wound up having to swap all the gears. I don't know if they develop a ware pattern with each other which causes this but it sounds like running a combination of new gears w/ old might be your problem. Probably not what you wanted to hear.
Old August 29th, 2010, 03:31 PM
Wolf Fabrication
Sterling Archer
'08 D3
Sad thing is that I have a complete set of matching gears and only replaced the high range and intermediate gears!
Semper Fi!
Old August 29th, 2010, 04:08 PM
mikeslandrover
Mike Hammond
I think the crush sleeve is a one time thing too
Mike Hammond
Old August 29th, 2010, 04:42 PM
Wolf Fabrication
Sterling Archer
'08 D3
It is, but at least it's cheap!
Semper Fi!
Old September 12th, 2010, 09:44 AM
Wolf Fabrication
Sterling Archer
'08 D3
As a follow up for anyone that had this issue, after tearing down the tcase again it turned out to be the intermediate gear bearings and crush sleeve. The shaft nut was not torqued to specs. According to the rebuild manual the nut should be torqued so that no end play is felt, however, that leads to the issue noted above. Per several rebuild articles in LRM and LRO, the nut should be torqued until slight rolling tension is felt while turning the intermediate gear. I did the second method at that corrected everything.
Semper Fi!
Old September 12th, 2010, 12:50 PM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
Thumbs up
Jonathan,
thanks for the follow-up. A lot of times folks find out the cause of their issue and fix it, then they don't post the solution/fix. I appreciate your taking the time to help someone else in the future. You're a good egg, my man.
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old September 12th, 2010, 02:20 PM
Jonathan- does rolling tension mean resistance to turning the gear ? Kind of like a wheel bearing, tighten till it starts to bind, then loosten a .25. In this case no letting off due to the crush sleeve. Could you email me that article ?
Old September 12th, 2010, 04:26 PM
Wolf Fabrication
Sterling Archer
'08 D3
The article just said to turn until slight tension is felt and was careful to go real slow. Based on my recent ordeal, I would say backing off a 1/4 turn would be bad. You can't feel the same binding as a wheel bearing on the smaller taper bearings either.
I'll email you those articles.
Semper Fi!
Old September 12th, 2010, 11:12 PM
Got them thanks.
Old September 20th, 2010, 02:27 PM
easy's Avatar
easy
Dan Duncan
White '94 Disco 1
Jon,
Could you email me those articles as well? I think I might be having the same problem.
Old September 20th, 2010, 07:52 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by easy View Post
Jon,
Sure, PM or email your address
Semper Fi!
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
