transfer case broken wire mystery - Defender Source
Old August 11th, 2011, 09:43 AM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
I have a new to me 1984 90 RHD with 200tdi, LT77 and LT 230.
After addressing a transfer case seal issue I found a wire that apparently went to a brass-looking bolt on the transfer case, about 3 inches aft from the diff select lever (on the case). It is a blue wire with a white tracer. It also has a black wire going to the bolt. It is a real pain to access. Anybody know what it is for? I can't seem to find a wiring diagram that shows it. A good lead for that too would be appreciated.
Thanks!
Old August 11th, 2011, 09:59 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Off the cuff I would say its for the dash light to let you know that you have your center diff engaged.
Old August 11th, 2011, 10:01 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Looking at the wiring diagram, looks like it's the Center Diff Lock indicator switch.
Look at the "Instruments" page of the wiring diagrams, middle of the page on the right. It lights up when the center diff lock is actually engaged.
Old August 11th, 2011, 10:59 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Coloured wire is to the indicator light - diff lock engaged and the black is the earth wire.
Mike Hammond
Old August 11th, 2011, 02:38 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Damn you guys are good!
Land Rover 110
Old August 11th, 2011, 02:56 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
Yes, well said!
Thanks for the info!!!!!
~Sandt
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
» Defender Registry
TOAD
SaltyDog
Broken
Z.G
Add your Defender
