transfer case and electrical short - Defender Source
Old March 3rd, 2012, 10:56 PM
blenkush's Avatar
blenkush
Severin Blenkush
97 D90 LE, 10 Lotus Exige S, 05 LR3
97 NAS 90 with auto box. Fuse #17 (engine immobiliser, brake lights, turn signals) started blowing once in a while and got to a point where it blew as soon as I turned on the key. Ended up melting a gray wire with a black stripe I traced to the transfer case. I think it is connecter C683 going into the gearbox interlock unit?? When this is disconnected the fuse does not blow. It is not the low range light switch. Ideas on what failed? Is this a simple remove and replace with a new interlock unit (if that's the problem)? Thanks in advance.
Old March 3rd, 2012, 11:45 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Never had any trouble with my inter-lock solenoids, a '97 with 133K miles.
The shift lock solenoid helps with theft protection and keeping children shifting it out of park and possibly rolling away. Don't know if the shift interlock stays locked with the engine off.
Old March 4th, 2012, 09:09 PM
blenkush's Avatar
blenkush
Severin Blenkush
removing transfer box interlock
Thanks for the info. If the truck will run fine w/o the interlock it will not be replaced.
Is removing the transfer box interlock a job that can be done w/o removing the box? Never done this, looks like one needs to remove a plate that has a cylinder-like part sticking out held down by 4 bolts. Any tricks/tips out there? Thanks again!
electrical, transfer case
'97 NAS D-90 electrical short, ideas?? (please!) blenkush Defender Technical Discussions 0 December 23rd, 2011 06:36 PM
Electrical Gremlins cbass Defender Technical Discussions 9 March 20th, 2011 06:34 PM
Mystery bolt on the transfer case cbass Defender Technical Discussions 3 October 30th, 2010 01:32 AM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
