Transfer Case & Diff Oil - Defender Source
Old March 12th, 2013, 02:44 PM
Before I order anything is this what most of you guys use?
Red Line 57905 75W90 GL-5 Gear Oil
Also, checking on quantity to have on hand:
1.7 Liter for each diff on a 90
2.8 Liter for the transfer case
Also, what is the consensus on oil brand and weight for a 2.5L N/A diesel in hot Arizona?
I'm ordering from Amazon and this stuff would be a PITA to return if I buy the wrong stuff.
Thanks!
Old March 12th, 2013, 02:48 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I like this one for the diff's:
http://www.amazon.com/Royal-Purple-P.../dp/B0007QGT34
Old March 12th, 2013, 02:57 PM
I buy my lubricants at Tractor Supply in 5 gallon buckets. Dinosaur oil for me. I change it out frequently. A tip I got somewhere, was to buy a couple garden sprayers and fill them with gear oil, trans fluid, motor oil, whatever. You cut the nozzle off the plastic wand. A few pumps is all it takes to allow you to fill your various holes with the proper fluid. Since they have a built in trigger, you reduce spillage.
Old March 12th, 2013, 04:21 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Speak for your self!
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old March 12th, 2013, 04:32 PM
There was just no way to write that in a way that wasn't an opener for a punch line, so there ya go...
Old March 12th, 2013, 05:34 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I'm with Bill...use cheap stuff but change it roughly every 2k miles (2-3 months) because I wheel in water fairly often
Old March 12th, 2013, 07:09 PM
Not really needed unless you have bad seals. I wade a lot as well and have never had any oil contamination.
I think it is worth getting the better oil like above for the transfer case. They can run hot.
Old March 12th, 2013, 07:10 PM
A decent 15W/40 diesel engine oil should work fine in your climate.
Old March 12th, 2013, 07:12 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Totally agree on the transfer case. I normally run Mobil1 in there.
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
