transfer case - Defender Source
Old January 25th, 2004, 05:45 PM
redrover
Guest
Posts: n/a
transfer case
I am in process of removing a transfer case on a 97 sw. I have removed everything the manual requires. the transfer case has three bolts and two threaded rods with nuts that hold it to transmission extension. Problem is the transfer case wont separate from transmission. Any one gone through same process?
Thanks jp
Old January 25th, 2004, 06:14 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
JP-
If you are positive you have removed all bolts connecting the two you may need to pry a bit. There are one or two pins/studs ~1/2 to 3/4" long that are like a press fit. I separated mine with the trans and x-fer out of the vehicle and we had to wiggle them apart until the studs came free. I think that may be your holdup as long as you've removed linkage and all fasteners. Good luck, let us know how the underdrive works out.
Tis
Old January 25th, 2004, 06:46 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
JP check to make sure you have all the bolts/nuts off. there is 3 on either side. Which makes 6 over all not 5. let me know how you make out. I can take pics
Legend in My Own Mind.
Old January 26th, 2004, 10:15 AM
redrover
Guest
Posts: n/a
Thanks Randy Tis, This morn before work,I looked for another bolt-and Damm there is another one hidden up behind the diff lock linkage/4lo linkage. it is in a tuff spot and should be a real treat to get at. My manual says there are only 3 bolts and one nut. Now there will be six fasteners. Any way thanks. jp
Old January 26th, 2004, 10:34 AM
JP did you make an adaptor plate to hold the T-case on your jack? I made one when I replaced my T-case last year and I still have it. The hardest part of the job was getting the new case on and bolted in. The adaptor helped allot. If you need borrow it all I ask for is shipping cost (around $5-10 for UPS Ground).
Old January 26th, 2004, 02:10 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
JP. I would borrow Mikes jack plate. When putting it back in it will be a total bitch and heavy. IT will make it easyer to line up.
Glad to help. I actually went out to mine and counted the bolts to make sure for you.
Old January 26th, 2004, 03:25 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
It's a whole lot easier on and off if you take the transfre gear out the back of the transfer box. The one behind the circular plate on the back of the transfer box, if there's wear on the output shaft from the main box this can hang up. I used a sling through the center hole in the seat box to drop it on the ground when taking the T box out. Getting it back in wasn't so easy as there's little space behind the T box before you colide with the chassis once you're clear of the out put shaft. Have fun
Mike Hammond
Old January 27th, 2004, 01:52 AM
redrover
Guest
Posts: n/a
Thanks Michael, I welded up a bracket that sits on my floor jack. I removed the screw that was eluding me and pulled case. pretty easy when you find all the screws. Duh! Any way ready to start gear swap. The Maxi drive directions are like Chinese to me , but it should be fun. I will shoot pictures in case someone else goes for conversion. Thanks for help jp
Old January 27th, 2004, 09:07 AM
What reduction did you get I think there are 2, 30% and 40%. Pics would be very cool also! Good luck.
Old January 27th, 2004, 02:41 PM
mikeslandrover
Mike Hammond
I've got some exploded diagrams from the LR parts manual that might help if you get to the pile of cogs and stage.
It helped when I rebuilt my transfer box. just let me know and I'll Email them to you.
Mike Hammond
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
