Transfer Case - Defender Source
Old June 1st, 2012, 02:41 PM
trumphair
Martin
97-D90
Transfer Case
When shifting the t-case from Hi-unlocked to Hi-locked, should I be able to do it by simply shifting the gear lever from right to left OR should I have to go up, over left, and down?
Old June 1st, 2012, 02:53 PM
just go left. no need to go into low.
Old June 1st, 2012, 04:32 PM
trumphair
Martin
97-D90
I guess the point of my post was should I be able to go straight over to locked without going up into neutral first (up and over)? Right now I can go from HI-unlocked (lower right corner) right over laterally to hi locked (lower left corner) without going up and over.
Trying to find out if my t-case shifter is busted.
Old June 1st, 2012, 05:12 PM
87 D110 (Ruby)
So it is a "H" pattern. You should have to go through that pattern for locked to normal
Old June 1st, 2012, 05:36 PM
trumphair
Martin
97-D90
Thanks, that was the answer I was looking for. Any thoughts on whats wrong or what the fix is?
Old June 1st, 2012, 07:36 PM
87 D110 (Ruby)
Frankly I have no idea. But I would first check to see if it is working. Only way I know is to get it on a lift start her up, put it in gear and see if when you change the wheels spin. Be integrating case if they do....but then the Q is "is it locked" or just spinning in L or H normal mode.
I'm done.......sorry
Old June 1st, 2012, 07:56 PM
Why do you think something is wrong? The diff lock and the high low shifting is completely separate. They work independently.
Old June 1st, 2012, 08:35 PM
87 D110 (Ruby)
The way this guy explains it he can go direct from locked H to normal H without coming down and across the gate. Doesn't work like that in mine.
Old June 1st, 2012, 11:43 PM
There is no gate. The two functions have nothing to do with each other.
Old June 2nd, 2012, 12:38 AM
I'm with Red on this one. Take another look at the pattern on the shift knob. It's a square not an H. No need to up or down to go over into our out of lock.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 2nd, 2012, 09:13 AM
87 D110 (Ruby)
Hmmmm ok
Old June 2nd, 2012, 10:51 AM
carlosz's Avatar
carlosz
Carlos
lock to unlock and vice versa is possible in any range, so as long as you are not spinning... that is if you are traveling above 35mph on high (example towing) and the truck keeps on getting squirmish, you move the lever to high lock and now you have a50/50 split f/r... if you are doing below 35 mph on low range and you are about to climb a hill so you want 50/50split again just move the lever to lock, when done move to unlock while on the move.... hi range to low range or viceversa you must be below 5mph if on the move, or completely stopped and in neutral.
if all is working well you should be able to move the lever any position if fully stopped and in neutral with engine running.. if this is not possible, there is a likelyhood the shifting mechanism is rusty thus binding...
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
