transfer case - Defender Source
Old September 2nd, 2010, 09:56 PM
grbec22's Avatar
grbec22
Roger Ramjet
1985 "90" no defender's back then.
transfer case
The LT230r transfer case is going. What is the best replacement way to go. The R transfer case is one of the older ones and parts aren't so readily available.
Old September 3rd, 2010, 01:06 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Just get an LT230t it's a direct swap with better bearings and bigger cogs - bit stronger.
Mike Hammond
Old September 3rd, 2010, 10:52 PM
berti1554
Robert Klima
84/110
1:1 was used on early Range Rovers only. It's an '85 D90 so it either has an 1.6 or an 1.4 (more likely)
Old September 4th, 2010, 03:50 AM
mikeslandrover
Mike Hammond
I'm pretty certain all 90's came with a 1.4.
If you're running standardish size wheels a 1.22:1 transfer box from a discovery is a good upgrade.
There's a huge thread on the subject running o the site.
http://www.defendersource.com/forum/...ad.php?t=15544
Mike Hammond
Old September 4th, 2010, 08:41 PM
That would depend on what engine the 90 has.... What engine? What gearbox?
Old September 4th, 2010, 11:16 PM
berti1554
Robert Klima
84/110
No, Mike is right. It has an LT230 and is my '85 so it has the LT77 trans. Transfer box ratio is 1.4; 1.6 was used on 110's only
Old September 5th, 2010, 03:14 AM
I meant....whether or not a 1.2 swap is a good idea or not depends on what engine it has..... Also it is good to know what gearbox. When new it could have had an LT95 or LT77, but through the years could have have anything put in there...
Old September 5th, 2010, 07:17 AM
mikeslandrover
Mike Hammond
The transfer box is integral on an LT95.
Only the 2.25 petrol 110's got a 1.6:1 transfer box because they had trouble moving under their own power but used a whole lot of fuel going nowhere fast. I know, I had one, It got a 200tdi transplant and a 1.4:1 transfer box within a month of ownership.
Then I bought a 90 2.25 petrol same problems( slow and thirsty) but a 1.4:1 transfer box as standard, that too got a 200 tdi and eventually both got 1.22:1 ratio transfer boxes, they're ten a penny over here.
By bigger cogs I meant that the cogs are wider, don't think the intermediate gears are swappable between an LT230t and an LT230r. The LT 230t is slightly stronger, saying that I've killed 2 One when the traper bearings came loose because the crush distance piece failed, ( rebuilt and still fine )the other I'm not too sure about but gear teeth came out with the oil
Mike Hammond
Old September 5th, 2010, 09:16 AM
All non-V8 pre-TD 110s had 1.6s. 2.25P, 2.5P, 2.5D.....
The OP needs to let us know the rest of the drivetrain...
Old September 5th, 2010, 03:33 PM
grbec22's Avatar
grbec22
Roger Ramjet
I have a 2.5 non turbo diesel.
Old September 5th, 2010, 06:11 PM
Then stay with the 1.4.
Old September 6th, 2010, 05:04 PM
grbec22's Avatar
grbec22
Roger Ramjet
Red90,
so what is the correct replacement transfer case? a T?
Old September 6th, 2010, 05:45 PM
mikeslandrover
Mike Hammond
Originally Posted by grbec22 View Post
Red90,
It doesn't really matter, the t is probably stronger, it's the ratio that needs to be right.
The ratio is shown by a sticker near the fill/level plug (if it hasn't come off).
Mike Hammond
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
» Defender Registry
Oliver
Squaretyre
Bobby
curry
Add your Defender
