Transfer box linkage acess - Defender Source
Old March 28th, 2010, 04:34 PM
Cecil6304
Cecil Tisdale
97 D-90
I need to reconnect the Hi-Lo linkage on a 97 D-90. My hands and arms do not fit into the space available from beneath the vehicle. Will pulling the tunnel from inside the car provide good acess?
I'm working in a condo parking lot and maint is prohibited, so dropping the tranny/xfer case is not an option. (I did use the search function to no avail)
Cecil
Old March 28th, 2010, 05:22 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Yes - you may also want to remove the passenger side floor.
Old March 29th, 2010, 09:58 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I was able to sit behind the t-case on the floor with the rear shaft removed. Reconnected everything no problem
Legend in My Own Mind.
ac
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
Transfer Box Fill Plug matthewwcarey Defender Technical Discussions 5 February 18th, 2008 04:21 PM
Linkage - gear box shot ? My 1st time (pop!) paulb Defender Technical Discussions 10 January 21st, 2008 07:07 PM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
