Transfer box input bearing preload - Defender Source
Old October 18th, 2008, 04:15 PM
reb78
REB
Land Rover 110
Just a quick question... How important is it to check the transfer box input bearing preload when replacing the original for a cross drilled one? I haven't changed/touched the shims or bearing tracks, i've just fitted the input gear with new bearings and wondered if i need to get the preload checked as i don't have a gauge precise enough to do it myself. Do people just fit these in situ and not worry or is it really important to check this?
Old October 21st, 2008, 02:02 PM
TND90's Avatar
TND90
Keith Allen
94 d90 ST
Ask Roadsiderob on this board. He is the pro at transfer cases.
"There is no normal life Wyatt, there's just life."
Doc Holliday
Old October 21st, 2008, 05:31 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Did you not replace the bearing races as well? If you installed new bearings, you should really replace the old races as well, and then check the preload (and shim as necessary). And yes, Rob Dassler would be the authority on this.
Old October 23rd, 2008, 06:36 AM
reb78
REB
Land Rover 110
Can i replace the front raceway without dropping the transfer box? - i wasn't sure you could - thats why i left the old ones in. Obviously the parts wear together over time so the old raceways would match the old bearings somewhat, but is it ok to use the old raceways with the new bearings or will this likely result in preature wear and failure of the new bearings?
Old October 24th, 2008, 04:15 AM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I know it's not the answer you want, but I think you've answered your own question. Yes, it will wear prematurely. How much depends upon how much of a wear pattern has developed.
It might be possible to replace the front race in situ, but it will be much easier with the box out. I just swapped out my TC so I know it's not a fun job. But it's not horrendous either. Make sure you have a new input seal ready to install as well.
Old October 24th, 2008, 08:47 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
For that matter, if it's low mileage, could you swap the original bearings onto the new crossdrilled input gear?
~Scott T.
'95 D-90 ST - AA Yellow
Old October 24th, 2008, 04:32 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
That's the option I'd probably go with if I was deadset against tearing everything apart. You should still check the preload as the new input gear may have a different bearing shoulder dimension. At the very least, measure the shoulder-to-shoulder dimension, compare it to the old gear, and adjust shims if necessary. Assumption is that the old gear was properly preloaded.
Old October 24th, 2008, 05:32 PM
I would just slap it all back together. Other than the center crush sleeve (which I have seen reused) they seem pretty tolerant of less than ideal situations.
Just keep oil in it and it will be fine.
Old October 24th, 2008, 08:23 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
Yeah what he said!!!!!! X2
Old October 28th, 2008, 11:23 AM
reb78
REB
Land Rover 110
Thanks for the replies. The old bearings had done 150k miles so i reckoned it would be a good time to change them.
I hadn't thought of the races until Ryan mentioned it above as i assumed these were hard wearing and didn't really wear as much as the bearings but of course it makes sense to change them. (i figured that if i change wheel bearings on older vehicles i wouldn't change the hubs unless they were damaged and i applied similar thinking to this - rightly or not).
The truth is that the transfer box was off and i'd just bolted it all back up on the day i started this thread so i was horrified that i'd have to drop it again to do something i should have done in the first place (especially after i'd returned the engine hoist to my uncle an hours drive away!)
I think i'll replace the gear and new bearings with the old races and see how we go.... (the races are in really good nick - no grooves or score marks). I'll still check the preload as with the old shim it was really tight.
Old October 29th, 2008, 05:04 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Reb,
Hope it all works out for you. I know what it's like to have everything buttoned up, and then realize you should've done something while it was torn apart.
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
T-case input shaft Bearing #s Mike Hippert Defender Technical Discussions 10 June 8th, 2005 06:52 PM
