Transfer Box Diff Lock Question - Defender Source
Old February 23rd, 2014, 07:51 PM
Surfin' Elvis
Chuck
95 RRC 300tdi/wvo conversion
95 RRC, which I refitted with a 300tdi and Auto transmission.
While on the beach today, only had front wheel drive. Luckily the front axle got me back to solid roads!
I was unaware of the manual diff lock feature on my transfer box at the time, so I did not attempt to utilize that feature. Never needed it before and I have this truck on the beach almost weekly for three years.
Any ideas where to begin diagnosing the problem? I have had this truck in some deep sand and never had any issues until today. No strange noises or vibrations.
When I purchased the 300tdi and trans, I was told it had been removed from a 94 Disco, but I cannot be sure. I also cannot verify what type of trans and tranfer case I have, so any help with identifying them would also be helpful.
Thanks in advance.
Old February 23rd, 2014, 08:15 PM
Surfin' Elvis
Chuck
The t-case came with the package, so not sure.
So it may be normal that I only have front wheel drive most of the time? Never had an issue like this before.
Old February 23rd, 2014, 08:16 PM
Surfin' Elvis
Chuck
edited
Old February 23rd, 2014, 08:44 PM
One wheel turning with open diff lock is perfectly possible. Diffs send power to the wheel with least traction.
Therefore it looked like you only had one wheel drive.
Old February 23rd, 2014, 08:59 PM
Surfin' Elvis
Chuck
Not sure why I never had this problem before, but I am going to test this out!
Old March 30th, 2014, 07:39 PM
Surfin' Elvis
Chuck
I finally hooked up a light to the difflock light switch. Screwed the sender all the way in, light comes on. Backed it off just until the light went off, then one-half turn out. Engaged the difflock with lever, no light. I "encouraged" the actuator arm with a little leverage from underneath, still no light.
There are no strange noises from the transfer box. Truck drives fine.
Are there any further fixes I can try before dropping the box for a rebuild?
Old March 30th, 2014, 09:00 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
The light is no indication of the cdl engaging. I spent 2 hours getting the lights to work properly, when the transfer case was working just fine.
Check the linkage adjustments
Old April 1st, 2014, 11:11 PM
michael67's Avatar
michael67
Michael White
110 Tdi
I thought the procedure was put it in difflock, screw in the switch until the light turns on, turn the switch another another half turn, then tighten the lock nut.
If you're doing that and still having problems, you may need to replace the switch. Order genuine Land Rover; I ordered the cheap Britpart one and it didn't work.
Defender TD5 diff Lock light Padraig10 Defender Technical Discussions 5 December 12th, 2013 01:08 PM
Defender Transfer Box Service BeardBob Defender Technical Discussions 13 November 12th, 2013 06:51 PM
Steering box question jayz Defender Technical Discussions 3 August 19th, 2012 11:31 AM
Transfer case question Wiley Defender Technical Discussions 7 January 1st, 2010 06:39 PM
Transfer box input bearing preload reb78 Defender Technical Discussions 10 October 29th, 2008 05:04 PM
