Trans went Boom - Defender Source
Old July 26th, 2007, 02:13 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
Trans went Boom
Driving down the freeway the other day and I pulled off to get fuel. Shifted into first gear to pull away from a stop light and I head a Loud BOOM followed by a lot of clunking!!! Darn, I thought my t-case slipped out of high into neutral or something. After shifting from high to low and locking the center diff it still didn't move
Old July 26th, 2007, 04:44 PM
Monkeyboy
Guest
Posts: n/a
Have you tried 2nd & 4th just for fun?
Sounds like you might need some of those nasty, oily, machined bits that RoversDownSouth have so much experience with .... Rob?
Old July 26th, 2007, 10:00 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Sorry to hear that! Good luck & wish I could help!
Old July 26th, 2007, 11:12 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
I know it is blasphamy but I think Im actually going to go back with a chevy 5.3 4l60e auto combo....
Nah sayers all around but I can get the engine and tranny for what it will cost me to rebuild the trans or switch to an auto. All I have to do is figure out what t-case or adaptor to use????????
It will be the prototype for my next project
Old July 27th, 2007, 12:32 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
You have mad skeeills rebuild it you can get a kit from George & I am sure others. I might think its less work than the gm stuff.
Old July 27th, 2007, 12:37 PM
Monkeyboy
Guest
Posts: n/a
Rebuilt it ... replace with one from Rob ... either way.
All depends on your $$ vs. Time.
I rebuilt the LT77 in the old sedan, and it wasn't too scary.
I replaced the LT230 in the Disco with one from Rob.
3rd - Detroit Locker 4.10, Auto Trans, Steering Box, ABS Pump mudrover For Sale - Parts 2 August 9th, 2004 11:25 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 01:16 AM
Auto trans output shaft extension needed JCRover4x4 Wanted 1 June 15th, 2004 09:10 PM
Check your trans filter! {manual} Bowtracer Defender Technical Discussions 5 May 25th, 2004 09:32 AM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 09:45 AM
