trans filter change question - Defender Source
Old December 17th, 2003, 11:58 AM
J4hand
James Forehand
83 110 200tdi
I am going to change my transmission fluid and filter soon and I have two questions: 1) Will I need exhaust gaskets, studs, nuts to reattach the y-pipe after removing it to pull the sump, 2) The manual calls for Dextron IID, can I use Dextron III
Thanks, BTW this is on a '97 automatic.
Just did my first oil change...quick question. advnirvana Defender Technical Discussions 2 July 4th, 2009 08:32 PM
fluid change question JBOD77 Defender Technical Discussions 15 March 29th, 2009 11:22 PM
Changing fuel filter question ollieskins Defender Technical Discussions 8 July 5th, 2008 11:27 AM
Check your trans filter! {manual} Bowtracer Defender Technical Discussions 5 May 25th, 2004 10:32 AM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
