Tranny tunnel vibration when clutch is depressed - Defender Source
Old May 31st, 2016, 08:11 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
Just a week ago I noticed this issue. When I depress the clutch the car shifts fine (well relatively speaking for a 1994 NAS defender 90 from 1st to 2nd) but at the same time I get quite a noticeable vibration in the vehicle from the tranny tunnel (underneath center console). That being said it is occurring occasionally (the vibration) even if the clutch isn't depressed (at certain RPMs).
Appears to be some form of clutch chatter that always happens when I depress the clutch but also happens sometimes without the clutch depressed. So that part has me thrown off. Assumed it could be some fluid leaking into the friction surfaces but not sure that explains the vibrations when the clutch is not depressed.
Thoughts? I show no signs of leaking on to the garage floor that is noticeable.
Will
Old May 31st, 2016, 08:21 PM
This is probably a nutty idea, but how are the UJs? Something's unbalanced under there!
Old May 31st, 2016, 08:44 PM
wmatos1001's Avatar
wmatos1001
William
Not that nutty of a thought thank you. Will look into that first thing tomorrow. Also maybe thinking it is possibly related to a drive shaft issue as well.
Thanks!
Old June 1st, 2016, 07:38 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Perhaps hot spots on the flywheel from the pressure plate wear? Obviously check all the external stuff first. I'd pull the brake drum and check inside there as well. Oil leaks from the tcase can get things sticky in there too.
Old June 19th, 2016, 08:08 PM
wmatos1001's Avatar
wmatos1001
William
Update: after 3 test drives with my local mechanic we trouble shot the vibration to actually coming from the rear of the vehicle. It was difficult to pin down because the vibration in the rear transferred to the low range shift link and made it seem as if it was originating under the tranny tunnel but it wasn't.
Turns out it was the rear U-Joint. Simple $300 job parts and installation included and problem solved.
Thanks for the posts!
How to get a lt77 tunnel onto a r380 tranny without removing seatbox!!! airbornrover Defender Technical Discussions 10 October 18th, 2015 03:35 PM
Knocking when low RPMs but Accelerator depressed near floor rijosho Defender Technical Discussions 6 August 1st, 2011 03:32 PM
Vibration when I press in on the clutch bstraw Defender Technical Discussions 5 May 31st, 2007 07:10 PM
Defender automatic tranny tunnel cover Method PHX Wanted 2 April 6th, 2006 04:49 AM
vibration around 20 mph Rick Carlisle Defender Technical Discussions 19 August 25th, 2004 07:41 PM
