tranny problems.. not the RuPaul kind - Defender Source
Old August 14th, 2010, 11:35 PM
tjgraham's Avatar
tjgraham
TJ Graham
'94 D90
('94 with an LT77) I did a mild trail run last weekend and experienced some disconcerting tranny symptoms. During a moderate climb early in the run, I noticed that even though I was giving it more throttle, I wasn't getting any more power - just higher rpm's. Later in the run it happened again, only this time the climb was steeper and I lost forward momentum. I braked, re-shifted and tried to start climbing again and the thing just sat there like an automatic in park.. rpms, but no movement forward and no drifting backward. I had to back down that section. The rest of the way was down hill, and it seemed ok for that and the rest of the drive home. What's the consensus? Do I need to start shopping for an R380?
(oops.. definitely didn't intend this for the for sale section)
Old August 15th, 2010, 12:23 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Burnt smell?
Old August 15th, 2010, 12:41 AM
tjgraham's Avatar
tjgraham
TJ Graham
'94 D90
No, didn't notice a smell at all.
Old August 15th, 2010, 08:13 AM
willismatt25's Avatar
willismatt25
Matt S
1994 D90
Clutch??
Old August 15th, 2010, 09:39 AM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Sounds like clutch to me. My Austin-Healey did the same on a steep hill. The clutch didn't burn, it was just worn out. It had been slipping for a while, but that hill was the last straw that caused me to replace the clutch.
John Karlsson
Hope Valley, RI
Old August 15th, 2010, 09:51 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It is pretty easy to test the clutch slippage on hard pavement, in a low gear, to see if it is a clutch issue. What is the mileage on the clutch?
Land Rover 110
Old August 15th, 2010, 10:17 AM
John_Karlsson
John Karlsson
According to my experience, that should be a high gear. If you accelerate hard (well, my clutch slippage happened in an Austin-Healey), that's when you should notice slippage.
With a manual transmission, I don't see how the transmission would slip. It's more of a go/no go situation.
John Karlsson
Hope Valley, RI
Old August 19th, 2010, 03:40 PM
tjgraham's Avatar
tjgraham
TJ Graham
'94 D90
Thanks a bunch for the input, guys. I think the clutch has ~90k miles.
My local wrench agrees that it sounds like the clutch.
problems
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Wanted, NAS 1995 D-90 (Tranny) Transfer case Roverville Wanted 3 November 28th, 2005 02:14 PM
Wierd tranny question? D90user Defender Technical Discussions 6 November 15th, 2005 10:17 AM
Tranny leak?? mspell Defender Technical Discussions 3 September 8th, 2004 12:43 PM
Server Connection Problems chrisvonc Community News & Announcements 1 July 25th, 2004 10:22 PM
