Tranny leak?? - Defender Source
Old September 8th, 2004, 11:30 AM
mspell
Michael Spellman
Tranny leak??
I was over my buddies place for a BBQ, next day he called me & said I left a 1'x2' spot on his driveway. He couldn't be more specific than that, i.e. identify color & so forth. I got under the D-90, & saw nothing of note, there was a few spots on the leading edge of the tranny that looked reddish tinged. How can I possibly tell if the tranny has leaked out fluid? It runs/shifts fine, no difference that I can tell(I've only driven it 2 miles since). Is there any immediate feeling that I could discern? I might as well do a fluid change, but it was just done 2000 miles ago. Any advice would be great.
Michael
Old September 8th, 2004, 12:17 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
Originally Posted by mspell
...How can I possibly tell if the tranny has leaked out fluid?
uhm... look at the dipstick?
On a more serious note...
I would imagine your tranny would whine or clunk louder if it runs out of fluid. But I would begin by checking the dipstick and fill as necessary. Go back to your friend's house and see this 1' x 2' spot and remember how you parked your truck and try to figure out where it lines with. I wouldn't worry too much about it....
Glenn
Old September 8th, 2004, 12:30 PM
mspell
Michael Spellman
Alrighty, where is the dipstick? It is the R380 manny tranny, I was unaware a dipstick existed.
Old September 8th, 2004, 12:43 PM
you will have to crawl under and on the passenger side of the trannyI think, ( I should know this) there is a T-55 torx plug that you will have to remove to check the level. same idea as the t-case but its not a torx plud its the same as on the diffs, and if fluid runs out or you can easily touch it I wouldnt worry about it. You may want to change it, or check your t-case level also. There is no dipstick.
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
