tranny issue - Defender Source
Old September 12th, 2012, 07:49 AM
JBOD77
Jonathan
1995 D90 ST Beluga Black
tranny issue
95 NAS D90, 41,000 orig miles. Orig R380 trans. Ok, So yesterday all was well, I ran out to a doc appointment and couldn't move the selector over to reverse. Got back on the road and 1-4 work fine, always was a good amount of positive feedback when changing gears, "toothy" feeling but no grinding or anything. Long story short, i can get into 5th and reverse but I have to firmly move the selector to get through the gate. Once in, it respond normally. Fluid was changed about 4 months ago to Redline synthetic. Fluid level is good. I'm guessing something on the top end but I am a true neophyte with regard to transmission assembly/reassembly. Any thoughts?
Thanks All!
This is where I'm supposed to write something witty and funny; or something.
Old September 12th, 2012, 10:18 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I thought Neil would be the original poster with a title like that...
Old September 12th, 2012, 10:54 AM
JBOD77
Jonathan
i could see that.
Old September 12th, 2012, 12:16 PM
JBOD77
Jonathan
Nothing? No thoughts/suggestions?
Old September 12th, 2012, 12:32 PM
Sorry still rotflmao on the title.
Where in the clutches travel does it engage? How's the clutch fluid level
Old September 12th, 2012, 01:47 PM
Check the clip guy that is the reverse lock out.
Old September 12th, 2012, 02:17 PM
JBOD77
Jonathan
ron, that would be on the top end? accessible under the selector from the cab? i'll look at rave
Old September 12th, 2012, 02:18 PM
I keep getting mixed up with LT77s, but I know it is in the top end somewhere.
Old September 12th, 2012, 03:20 PM
Your getting old. Happens to the best of us. Your probably already make grunting and sighing noises when you stand up or sit down.
-Jeff
I have been doing the latter since I was in my teens so nothing has changed.
Last R380 I did was near on a decade ago so even to remember anything is worth something. I swear I can still see how everything lines up in the pictures in my head but I don't have one of the top as I think I just checked it and it was fine.
Old September 13th, 2012, 10:00 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Thanks All!
I had same issue. Driving on highway, normal speed, kicked it out of gear and then would not take fifth; funny clunky sound..... got home on 4th and voila, no reverse. From what I read some king of shaft break.... nevertheless, smoked tranny..... swapped it with use I scored..... or you can have a rebuild for $2K...... sucks
Old September 13th, 2012, 11:03 AM
Since he can get into 5th and reverse it is less likely that shaft broke, but that is a somewhat common issue with R380s. More likely is something like the reverse lock out.
Old September 13th, 2012, 05:46 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
synco issue. Mine did that. Tranny felt very cluncky and then slipped. Got home but woke up one morning and the gremlins had been at work - reverse would not engage and another gear (do not recall which but my original post is on the site somewhere). Rowed to the shop - looked at the tranny and it was a simple inexpensive fix. Very happy as I was already sourcing replacements.
I'm contemplating thinking about thinking about it!
Old September 13th, 2012, 06:19 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
did you get any go with yours? mine, reverse completely dead and 5th no go with ugly noises.... from all i read & spoke to suggested replace, which i did.... would suck if i didnt need to replace....
I initially misread initial post, didn't realize was a stuck issue.....
Old September 13th, 2012, 08:03 PM
JBOD77
Jonathan
It's not a no go issue, 1st thru 4th run sweet. It's the move from 4th to 5th that's trouble. If I double clutch it should rule out a bad synchro which I've tried and it's still the same. In gonna go with Ron here but haven't had to open the top end of the transmission
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
Wierd tranny question? D90user Defender Technical Discussions 6 November 15th, 2005 10:17 AM
Tranny leak?? mspell Defender Technical Discussions 3 September 8th, 2004 12:43 PM
