tranny gone bad? - Defender Source
Old July 31st, 2010, 01:07 PM
grbec22's Avatar
grbec22
Roger Ramjet
1985 "90" no defender's back then.
tranny gone bad?
I was out today with my 85 90. I backed out of a spot then as I started to go foward. I heard a sound similar to the sound a cv joint might make when you make to tight a turn. Needless to say I made it about a hundred yards before I could no longer shift. I'm running a 2.5 n/a diesel with a LT 77. If the transmission is dead, should I stay with a LT77 or can I upgrade to a r380. I don't know if the R380 will work with my engine. I have tinkered with the idea of changing the engine since it is slow. Would a 300 tdi or a 200 tdi be better? Especially mated to either transmission. Which is the best way to go?
Old July 31st, 2010, 08:52 PM
grbec22's Avatar
grbec22
Roger Ramjet
with the center differential locked I have power to the wheels. I'm thinking CV joint.
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Wanted, NAS 1995 D-90 (Tranny) Transfer case Roverville Wanted 3 November 28th, 2005 02:14 PM
Wierd tranny question? D90user Defender Technical Discussions 6 November 15th, 2005 10:17 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
