Tranny & LT230 - Page 2 - Defender Source
Old July 3rd, 2015, 06:51 PM
galpin, you have enough junk!
Old July 3rd, 2015, 07:46 PM
Hey now, you can never have too many spares.
Jonesy, if your input gear is not cross drilled I can do it for you, but it would need to be this week since my TechShop membership is about to run out and I don't plan on renewing it.
Originally Posted by pendy
I'm here for the D's
Old July 4th, 2015, 09:42 AM
87 D110 (Ruby)
the TC is good - thanks Charles - it has a cross drilled input gear.
Issue now is a gearbox/tranny with the right suffix etc...guess I should have done research or asked folks first - but I couldn't find info on the board. At least now we have it.
Old July 4th, 2015, 10:17 AM
Some info here: Ashcroft Transmissions
The LT77 was introduced to the Landrover range in approx 1983 with the suffix 'D' box and was developed over the years to the suffix 'H' which was last used in 1994.
The 'D' and 'E' are very similar the only difference being the reverse gear was a little fatter in the E, When they went from 'E' to 'F' larger layshaft bearings were used.
The 'G' was further improved by all the gear teeth including the pinion getting approx 20% thicker. Also a much wider pump was used to increase the lubrication and cope with the fact that some of the LT77's were now being supplied oil cooled, ie V8 NAS 90, 3.9 RR Classic and the 3.5 EFI Discos.
The 'H' (termed the LT 77S) was the same as the 'G' in terms of strength but used a different synchro set up called the'Double Synchro', In reality it didn't work much better.
The other fun thing to consider is the prefix as that affects the gearing... You have a 51A there which has extra low first and second.
Land Rover Gear FAQ
The reality is that the 200TDI works best with the boxes that came with the engines, "56A" and "H" and a 1.4 t. case. Strong enough and a better 5th gear for the highway. The other "good" option is the 51A box as long as it is a later suffix, especially for the off roader type, but you do lose the highway gearing unless you go to a 1.2 transfer case. (This is what I have 51A/G/1.2)
So, anyone converting to a 200TDI, get the damn box that was with the engine....
Old July 4th, 2015, 12:05 PM
87 D110 (Ruby)
It looks like the one in it - that failed - was a 56A, that was also rebuilt by Ashcroft.
Old July 4th, 2015, 12:33 PM
Oh, I see that now. Well get that one rebuilt then, or if you feel rich get a short R380 as they have the same gear ratios.
What exactly is wrong with the current box?
Old July 4th, 2015, 01:56 PM
Jonesy drove it
Old July 4th, 2015, 02:18 PM
87 D110 (Ruby)
Hahaha
------ Follow up post added July 4th, 2015 02:27 PM ------
I think my plan will be something like this:
Take the TCase off the D suffix one I got from Newman, and put that gearbox in the Defender and mate it to the 1.4 TC in the truck then drive it
Send the better gearbox in it currently to get refurb'd then when that comes back, replace the D suffix one which I hope will last long enough.
Alternatively, I send the newly acquired one to get some refurb'd work done on it but believe that will be throwing money away.
So that's the plan right now.
I need the swap to be done in one day so I will begin acquiring all the needed crap so that can happen.
Old July 4th, 2015, 05:54 PM
Except that sounds like a lot of work to swap it twice. Where are you sending it to get refurbished? Can you not pay a core fee and send yours after and get it refunded? If it's from the UK I think shipping would kill the deal for sending a core.
And you can't make room in the garage for this?
Old July 4th, 2015, 08:35 PM
Mr Nasty's Avatar
Mr Nasty
james
2005 Td5 110 double cab
A 1.6? I struggle with a 1.4 being too low geared, depending what engine you have and tyre size, but I find the 1.2 Discovery Tbox to make a Defender just little bit more civilised, just a little though. A 19j will struggle with a 1.2, but a 300tdi should be ok unless your running massive tyres.
Old July 4th, 2015, 08:40 PM
I'd run the d till it dies which has been many years in my experience (actually still going since 2009) then and only then swap in the rebuilt l77s.
In my life the following has held true of boat and rover parts. If you have the new replacement, the suspect part never dies.
Old July 6th, 2015, 11:25 AM
87 D110 (Ruby)
JEEZ....turning into a PITA.
So I found a guy in Atlanta that does reconditioned gearboxes - Land Rover Defender/Discovery gear box repairs | Woodstock | eBay Classifieds (Kijiji) | 35737073
His name is Mark Storey - anyone had any experiences with him? He wants $2K for a rebuilt one - shipped to me.
Also here is my gearbox serial number - the receipt from Ashcroft shows a rebuild (matches the stamp on serial #) and it says LT77 "S" suffix which would have a transmission oil cooler on it. I think this is the "best" LT77 for a 200TDi from what I have seen.
Dave Ashcroft doesn't have records going back that far, but I asked him for any information he has on it.
Old July 6th, 2015, 11:55 AM
87 D110 (Ruby)
yeah - but he is up in NY now...grrr.
Old July 6th, 2015, 12:08 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
kidnap him?
Jimmy Buffett
Old July 6th, 2015, 12:31 PM
So true!!!
Old July 6th, 2015, 01:45 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Isn't ordering a 77S unit and swallowing the shipping and core charge well under two-grand?
445(unit cost)+200(whore charge)+200(shipping to South Riding)=845*1.6ish = $1350
Old July 6th, 2015, 02:28 PM
And 350 pounds more to get a stumpy R380 (995 versus 645) is worth thinking about, giving around $1900 total. Sell the broken box for a couple hundred for someone to rebuild.
What oil have you been running?
Old July 6th, 2015, 02:31 PM
Naplm00
Matthew
lol @ whore charge
Old July 6th, 2015, 02:36 PM
87 D110 (Ruby)
Originally Posted by Naplm00 View Post
lol @ whore charge
Clay is always thinking ahead...
Yeah guys now you see my dilemma? Coupla grand versus putting a suffix D one in it and running with it - as Doug said he has had one since 2009 against a 200TDi...
shit.
Old July 6th, 2015, 02:44 PM
Naplm00
Matthew
I have a Suffix D in my 110 with a 200tdi and a 1.2 disco Tcase for about 55k
Runs great and shifts great. I use Redline MTL and it significantly improved shifts.
Also if you are pulling the trans keep in mind you may have to do a pivot arm, clutch and related seals once you get it apart
lt230
LT77 tranny & LT230 transfercase CDNRover For Sale - Parts 17 September 26th, 2011 10:24 AM
Has anyone put a temp senor & gauge on a ZF tranny? Hammertime Defender Technical Discussions 0 July 29th, 2009 08:28 PM
LT77 & LT230 from 200TDI ajh For Sale - Parts 5 July 23rd, 2009 01:44 PM
Wanted: 94 D90 Transmission R380 & Transfer Case LT230 WOVOKA Wanted 1 June 11th, 2006 01:23 AM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
