trailing arm opinions - Defender Source
Old June 18th, 2016, 06:35 PM
I need to get cranked trailing arms to complete my 3" suspension on my 110. RN has terra firma's for a decent price. or I could pay alot more for clearly beefier RTE.
That said, I've never heard of trailing arms being a weak point. Are TF's good enough or am I missing something? I dont need to add any more unncecessary weight.
Mark Kellgren
KM4BOR
Old June 18th, 2016, 06:53 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I had had no issues with the TF arms, I did put an extra FB washer at the rear of the chassis bushing to bring the Pinon angle back.on 2 inch lift.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 18th, 2016, 07:52 PM
What about Rockware?
------ Follow up post added June 18th, 2016 07:52 PM ------
Just thinking, you have a pretty heavy truck, you might want something stronger than Terra Firma.
Old June 19th, 2016, 12:25 AM
RTE is unmatched!
Old June 19th, 2016, 02:12 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
They were very competitively priced (I thought) the last time I looked into this. Castor correction custom made to your parameters is a nice aspect of buying from RTE.
Old June 19th, 2016, 07:38 PM
Rockware
to bad Rovertracks has closed shop
Old June 19th, 2016, 08:21 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Rte links are super beefy.
Old June 19th, 2016, 08:45 PM
thanks all. I'll stick with RTE.
Mark Kellgren
KM4BOR
Old June 19th, 2016, 09:56 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Did you finally get your truck back?
Old June 19th, 2016, 10:41 PM
nope. should be done next week. 4 month engine rebuild.
Mark Kellgren
KM4BOR
Old June 19th, 2016, 10:57 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Should be worth it though...
Old June 19th, 2016, 11:35 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Mark - if you use the RTE trailing links you might have to raise the sedimenter about two inches for clearance if its in the stock location. I never hit the canister itself but I did bend the cover for the can.
It also depends on whether you are running any lift - I'm on stock HD springs front and rear.
Rear trailing arm instalation jayz Defender Technical Discussions 9 August 31st, 2012 06:33 PM
DAP custom rear trailing arm bushings jorge Defender Technical Discussions 5 July 15th, 2010 12:12 PM
Radius arm and trailing arm nut size dave_lucas Defender Technical Discussions 3 February 25th, 2010 04:44 PM
Radius/Trailing Arm Install pcscharfe Defender Technical Discussions 10 August 30th, 2007 06:30 AM
Rear trailing arm bushing failure sheki Defender Technical Discussions 23 July 5th, 2006 09:20 PM
