Trailering a Defender 90 - Defender Source
Old September 30th, 2016, 09:58 PM
ghoregon
Greg H
1986 Defender 90 200tdi Ex-MoD
Hi all.
I'm trailering my 90 from Richmond, VA to Raleigh, NC tomorrow morning for its 200tdi transplant at Brian's shop. I've got it loaded on a Uhaul flatbed trailer with the engine forward, per the loading instructions. This seems to put a ton of weight on the tongue and very little on the tandem axles given the short wheelbase. Does it make sense to back onto the trailer so that more of the weight is centered over the axles, or is this a terrible idea? The rear of my tow vehicle ('05 Sequoia) is really sagging with it forward facing.
I appreciate any thoughts, since I don't have a ton of towing experience.
Greg
Old September 30th, 2016, 10:09 PM
KKilo23's Avatar
KKilo23
Kenny
Originally Posted by ghoregon View Post
Hi all. I'm trailering my 90 from Richmond, VA to Raleigh, NC tomorrow morning for its 200tdi transplant at Brian's shop. I've got it loaded on a Uhaul flatbed trailer with the engine forward, per the loading instructions. This seems to put a ton of weight on the tongue and very little on the tandem axles given the short wheelbase. Does it make sense to back onto the trailer so that more of the weight is centered over the axles, or is this a terrible idea? The rear of my tow vehicle ('05 Sequoia) is really sagging with it forward facing. I appreciate any thoughts, since I don't have a ton of towing experience. Thanks, Greg
Center the weight on the trailer/axles.
Old September 30th, 2016, 10:24 PM
ghoregon
Greg H
So rear facing is ok & preferable if it better centers the weight of the vehicle over the axles?
Thanks for the help.
Old September 30th, 2016, 10:41 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
We had to back on-to with the S1 88" as it towed like crap for the first three miles, once turned around it was fine.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 30th, 2016, 10:43 PM
mud ruts's Avatar
mud ruts
Chris Ray
97 Disco
Yes center it but a little forward, you need some tongue weight or the trailer will get out of control very fast.
Mud Ruts Off-Road Rover Repair shop 614.301.1574
Old September 30th, 2016, 10:50 PM
doesnt the uhaul flatbed have two axles and a fixed place for the front tires? why the concern about centering it?
Old September 30th, 2016, 10:56 PM
ghoregon
Greg H
It is exactly as you say. I think the 90 pulled all the way forward, as the trailer is designed with its fixed straps, puts a pretty heavy bias on the tongue.
Sent from my SM-G920P using Tapatalk
Old September 30th, 2016, 10:59 PM
its a two axle trailer behind a huge vehicle, why the concern about tongue weight?
Old September 30th, 2016, 11:06 PM
ghoregon
Greg H
Maybe I'm worrying about nothing. Just seems like the rear of my Sequoia is really sagging so was wondering if the trailer weight distribution should be changed. May be hard to tell from these pics, but does it look OK as is?
Old September 30th, 2016, 11:50 PM
mud ruts's Avatar
mud ruts
Chris Ray
97 Disco
If you had a real truck to tow with this wouldn't be a problem.
Old October 1st, 2016, 01:13 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
I see what you mean. I'm for turning it around. With the fixed forward wheel harness points, that would put the engine quite close to centered over the second trailer axel and still a fair amount of weight (the rest of the 90) forward for stability. But bring your keys and just swap it if it sucks.
"Barry is correct!"
Old October 1st, 2016, 01:16 AM
Maybe I'm worrying about nothing. Just seems like the rear of my Sequoia is really sagging so was wondering if the trailer weight distribution should be changed. May be hard to tell from these pics, but does it look OK as is? Sent from my SM-G920P using Tapatalk
Looking at those pictures, turning it around is a total no brainer. Your Toy will thank you.
Old October 1st, 2016, 09:24 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
As long as you maintain a sufficient forward weight bias you should be ok. Too light a tongue weight is much worse (more dangerous) than too heavy. Generally its recommended to have 10 to 15 percent of total weight on the tongue.
Old October 1st, 2016, 11:20 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Flip it around and add 50lb cement/gravel bags in the bed as required for proper tongue weight.
Old October 1st, 2016, 01:18 PM
ghoregon
Greg H
Hey all. I made it to Brian's shop just fine with it forward facing. I guess I was worried about nothing. As an aside, I have major Rover envy after visiting his shop.
Thanks for the replies.
Old October 4th, 2016, 12:45 PM
down_shift's Avatar
down_shift
Russell
Good that your tow was uneventful. Here is an interesting video on this very topic.
https://www.facebook.com/dunlaoghair...1663689527395/
Old October 4th, 2016, 05:23 PM
ghoregon
Greg H
Wow, that is pretty scary/interesting. I was definitely favoring the front just a teensy bit.
Old October 4th, 2016, 05:28 PM
classic4x4
J
Defender
Toyotas are tanks. Sequoias can pull anything.
Old October 4th, 2016, 05:44 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
That Sequoia is squatting pretty bad in the back. With the center of gravity too far forward on the trailer (ie too much tongue weight) you lose braking and steering control. Strive for a happy median and move that 90 back a foot or so.
Old October 4th, 2016, 07:02 PM
ghoregon
Greg H
Agreed, that's why I was concerned and started this thread. I think it may look worse because I have leveled it with taller coilovers in the front. I towed 150 miles with it this way and it drove way better than I anticipated. No handling issues whatsoever, though I didn't need to make any emergency maneuvers. Unfortunately, the Uhaul trailer isn't really setup to have anything other than the front axle fully forward so I was really glad it worked out.
I did pick up heavy duty 2" ratcheting straps from Home Depot in case I need to improvise on the journey back home.
Thanks for all of the input.
Greg
90, defender, defender 90
Trailering '94 Defender 90 Jakewassaic Defender Technical Discussions 7 December 7th, 2015 06:01 PM
Upgrading a 130 for heavy duty goose neck horse trailering? hmmrbrg Defender Technical Discussions 14 April 29th, 2015 05:29 PM
Trailering race car Jas0n Defender Technical Discussions 46 October 15th, 2014 01:42 PM
7-Pin Trailering Harness and 4-flat converter fishEH For Sale - Parts 7 November 6th, 2011 01:11 PM
