Trailer Wiring Installation - Defender Source
Old June 15th, 2015, 02:53 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I need to install a wiring kit on the 110 to pull a pop up. I feel like this should be rather simple and I'd rather not pay someone to do this. The 90 has it installed and when I look at it the wires run from the plug up towards the passenger side rear lights but then another set of wires appear to run forward. Not sure where they are headed.
Does anyone have photos of installing something like this? When I look online I get all the newer Rovers but not a 110 or a 90. Where do you tie in with the wires? What is the easiest kit to install for basic towing needs?
Alex
Old June 15th, 2015, 02:56 PM
Just buy a trailer plug that matches the trailer and install it. You need the conversion box to join the brake lights and turn signals. All the stuff is available at every auto parts store in the world. You may need a brake controller as well if the trailer has brakes.
Old August 27th, 2015, 04:07 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
You have any more info on the converter?
There's a million,of them out there
Old August 27th, 2015, 04:27 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I don't have a picture handy but bought a converter for about $25-30 at Tractor Supplies (or Walmart????). It was for a Ford or Chevy truck. The input was clearly labelled (brake light, headlights, reverse light, ground) and the output was what I was looking for (I.e. 4 pin standard small trailer plug).
The only part I am missing right now is the plug that will plug to the plug of my std wiring harness on the 90 (round plug) because I'd prefer to keep the it intact.
On the Disco, I was ready to just cut off the standard plug and put another style more readily available.
Since I do not have the wiring scheme/color codes, I was planning on simply figuring it out with a volt meter.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 27th, 2015, 04:34 PM
mdcoa's Avatar
mdcoa
Bill
1995 Discovery
If the round plug on the 90 is the same as the disco one, AB (or whatever they're called now--I guess they merged with British Pacific in my roverless decade) has a convertor that's super-simple--round 7 pin plug on one end and the flat four-pin on the other.
It's a bit expensive, but after looking for something similar and ending up with something very much not similar arriving on the porch, I went ahead and pulled the trigger.
installation, wiring
m116a3 tool trailer. would make great camping trailer greenmountainrover The Flea Market 6 May 21st, 2015 12:39 PM
1974 Rapier Missile Supply Trailer :: 1974 Sankey Rapier Missile Supply Trailer FV241 kraison Defender & Series Truck Registry 1 September 4th, 2014 02:45 PM
"That's Not a Trailer. Now THIS is a Trailer!" Wolf Fabrication Misc. Chit-Chat 14 February 8th, 2014 12:33 AM
wiring a trailer hook up jstrong98 Defender Technical Discussions 9 September 27th, 2006 09:51 AM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
